Swapping ignition questions.
Old Oct 5, 2016 | 06:45 AM
GSX_TO_EVO's Avatar
Ok here's the back story on everything. I just bought my 03 Evo which a snapped timing belt. While it was in the previous owners possession at a shop, some jackass tried to steal the car with a screw driver destroying the ignition.
I have a parts car that I can pull everything from, but my question is if I pull the ignition cylinder and immobilizer out of my parts car, will I still have to have the key reprogrammed or will swapping all the parts from the same car matter? Sorry I've tried to search but came up with no solid answers.
Old Oct 5, 2016 | 07:03 AM
Fast_Freddie's Avatar
Veteran: Navy
You could always swap the ignition and disable the immobilizer function via ECUflash...
Old Oct 5, 2016 | 07:09 AM
GSX_TO_EVO's Avatar
I've got to get power to the car before I can use ECUflash though. Will the car power on with the new ignition installed, and just not start?
Old Oct 5, 2016 | 07:11 AM
4b11slayer's Avatar
You just need to get to on position. You can get there with or w/o immob
Old Nov 30, 2016 | 01:40 AM
Rhyther's Avatar
Hi nate, i just had a similar situation. Some arsehole smashed my ignition in an attempted theft. Does abyone know if i buy an evo 8MR ignition barrel, will it work in my evo 8 GSR?
also how did ypy go with your swap from your parts car? Does your immobilizer still function? I'd like to keep my functioning as its what stop the their from succeeding
chaotichoax
Aug 15, 2010 10:06 PM
Braydo25
Apr 24, 2009 04:11 AM
EvOcHaRgeR
Oct 24, 2005 02:35 AM
arnold16890
Jan 30, 2005 01:33 PM
MR
17
Dec 20, 2004 12:45 PM
