Engine built
Old Oct 5, 2016 | 10:05 AM
benIX's Avatar
Engine built
Hello everyone,
I'm doing a 64 built. I do need to get an oil pan because the stock one is not reusable. Anyway I just want to make sure will this work with a 4g64 crank/block and Evo 9 oil pan? Is it even worth getting or should I just get the stock components?
http://realstreetperformance.com/Sho...-4G63-Oil.html
Thank you so much everyone.
Old Oct 5, 2016 | 08:44 PM
benIX's Avatar
Nobody? I can't use my stick because it's trashed so I need some advise on the one I posted about. Any help weather I should go with that or something else chime in and give me your 2cents
Old Oct 6, 2016 | 01:56 PM
JAM.evo.7/9's Avatar
It will work but you will have to do a little grinding because of the longer stroke of the 100mm crank. You will need to grind where the rod passes the scrapper.
Old Oct 6, 2016 | 02:01 PM
roni4g63's Avatar
When I put my 2.3 together, the rod caps hit the sides of the scraper, easy fix, you can either bend it if the block allows, of grind the sides a bit like I did. easy mod, works perfectly..
Ron
Old Oct 6, 2016 | 03:48 PM
benIX's Avatar
Thanks guys I will order it tonight.
Evoovasti
Apr 9, 2009 11:24 PM
Tallen
For Sale - Cars For Sale
Jul 23, 2008 12:53 PM
fastassfourdoor
12
Jan 1, 2008 02:03 PM
TopLevelPerformance
Dec 18, 2007 07:35 AM
