Anyone recognize this sound
Old Oct 9, 2016 | 01:55 PM
Womb Raider's Avatar
Veteran: Marine Corp
i was working on replacing a hose to my egr valve. Turned it on to see if my ses light would turn off and i then i start hearing this sound. Help?
(got the video working)
Old Oct 9, 2016 | 03:39 PM
Its a high pitch rotational sound that is likely coming from the cam gear side. Maybe timing belt tensioner
Its hard to say just listening, but could be other things rotational as well, like the alternator pulley bearing
Sorry to hear youre having problems. Nothing like correcting one & then something else pops up
Old Oct 9, 2016 | 04:49 PM
So I called my buddy that built the car and told me to take off the oil cap and see if the sound goes away. Which it did. Guessing bad pvc valve?
Old Oct 9, 2016 | 05:13 PM
Read more about people having problems with pvc valve. A lot of them are saying dipstick popping out when boosting is usually a first sign. I did have that problem until i put a spring on it . Think i found my problem. Thankfully its not an expensive fix.
Old Oct 11, 2016 | 09:13 AM
Originally Posted by garrin
hmmmm
hmm
Old Oct 11, 2016 | 06:12 PM
barneyb's Avatar
Blow through an OEM pcv valve in the direction of the valve cover and it seals. Try that with one from a parts house and it passes air in either direction - or at least that is my experience. Only a turbo car pcv valve needs to seal. If it doesn't you are pressurizing the crankcase to manifold boost.
Old Oct 12, 2016 | 03:04 PM
When i took the old pvc valve it didnt have a seal (seems to me like a silver ball) the new one i bought does.
SkippyMcGee
Northeast Region
Nov 7, 2008 10:03 AM
JYD
Southeast Region
18
Aug 28, 2008 08:03 PM
500hpOnPumpEvo
Feb 9, 2008 07:33 PM
CrackerJackToy
18
Jun 5, 2007 09:38 AM
evilempire76
Feb 22, 2007 08:56 PM
