So how much of a pain is it to do the accessory belt
Old Oct 17, 2016 | 11:52 AM
Evo_Goodness's Avatar
Mine is starting to squeal like a pig in the cold then continuously chirp at idle I can feel the ridges on the belt are in pretty rough shape but the think looks like a total nightmare to do compared to my sti's belt any pointers to make it easier I know about removing the front wheel and releasing the tension then putting an key in there to stop it is that all there pretty much is to it.
Old Oct 17, 2016 | 12:00 PM
gsrboi80's Avatar
With 2 sets of hands once the wheels off maybe 3 min.
By yourself maybe 10 once the wheel is off. I have a copy of the diagram in my tool box makes referencing the belt path easy
Old Oct 17, 2016 | 12:05 PM
heel2toe's Avatar
^What he said. Its a simple job. 1/2" breaker bar turn the tensioner slip an allen key in the hole to hold it pull off old belt and route the new one. Just be careful when you turn the tensioner as people seem to have a bad habit of breaking them. But if youre careful and keep it straight and true you shouldn't have any issues. The only tricky part is figuring out how the thing is routed. But even that isnt difficult its just a matter of figuring it out by referencing the diagram and using common sense as to which side the belt would be riding on the pulleys given that some are flat and others aren't.
Old Oct 17, 2016 | 01:26 PM
That's what I figured anyone have the diagram they can post up by chance ?
Old Oct 17, 2016 | 02:12 PM
heel2toe's Avatar
Diagram is in this thread. Not the greatest picture but should be all you need...
https://www.evolutionm.net/forums/ev...tallation.html
Old Oct 17, 2016 | 02:49 PM
Tekniq's Avatar
Old Oct 17, 2016 | 04:24 PM
Thank you yup mines the bottom still have my AC maybe this would be a good time to delete it how hard is it to rip all the AC crap out I never use it here in Oregon I like having my windows down
anthonypazsd
135
Apr 2, 2026 12:56 PM
neonglh
Oct 3, 2011 11:10 AM
anthonypazsd
Jan 31, 2010 03:01 AM
CeeBee
Mar 19, 2005 09:51 PM
