weird stalling issue
Old Nov 29, 2016 | 02:57 PM
Fedetronchet's Avatar
Hi, greetings from Argentina, im having a very weird issue, when i start the car it idles perfectly but as soon as i move it 5 meters it starts stalling, idling at 600rpm, i did a vacum test it was all good, also i have no fault codes at all, if i let the car idle it can be there perfectly for 2 hours as long as i dont move it.. i cleaned the IAC can it be that? problem started just after i wired the wideband into the ecu folliwing the tutorial here in evolutionm, i returned everything back to stock but the problem continues, any thoughts? thanks very much
Old Nov 30, 2016 | 11:10 AM
MrGalantkid's Avatar
Does the car move freely? I mean...is there weired "rolling resistance"?
Have you tried another working MAF sensor?
I had a similar issue years ago intermittently when my car would experience load it would stall. The issue ended up being a bad MAF sensor.
Old Dec 2, 2016 | 03:35 PM
Ferp's Avatar
Did you let your ecu relearn idle? Let it idle for ten minutes with all electronics off, such as lights, radio, fans, what not. Afterwards idle for ten minutes with everything on (highbeams, radio, fan, rear window defroster, etc).
Old Dec 3, 2016 | 07:01 AM
Chris Smith's Avatar
sounds like a "load" issue. is it tuned?
Old Dec 10, 2016 | 11:13 AM
thanks everyone it turned out to be a faulty IAC
brianbarnesevo8
10
Jul 23, 2018 07:46 PM
irwintan27
Nov 10, 2016 09:37 AM
MRblack06
Mar 22, 2014 04:48 PM
JKD
Aug 29, 2009 05:20 PM
