RPM spikes when clutch is disengaged
Old Dec 11, 2016 | 02:17 PM
youra6's Avatar
I have a BBK Full setup with a Exedy Twin Disk clutch only making around 400whp/400wtq (uncorrected @ 5900ft altitude).
I recently went Speed Density with a VTA Tial Q BOV.
Only when I apply heavy or WOT throttle and shift gears, the RPM quickly spikes and go back down. If I apply light or moderate throttle, it shifts fine.
I have checked for user error by making sure my foot wasn't on the gas. It still goes up. This happens across all gears.
3 Possibilities in my mind:
  • Compressor surge from too stiff of spring in BOV
  • Clutch Slip
  • Sticky trottle
The TD shouldn't slip at that level of power. I put my car in 4th going 30mph and floored the gas. It was sluggish but both my RPM and speed slowly went up.
A side note, when I let off my gas, I almost always get a fluttering sound. No surge DURING accleration, only when I let off gas. If I go WOT, I get a clean cut BOV sound, no fluttering.
Old Dec 14, 2016 | 06:32 AM
Jmills's Avatar
Sounds like it very well could be compressor surge, I can't remember, does the BBK Full have an anti-surge intake side? Also what spring are you running in the BOV?
Old Dec 14, 2016 | 05:30 PM
youra6's Avatar
Thanks for responding.
I don't think its compressor surge because it doesn't flutter as I am accelerating (sometimes it does by rarely). I usually get fluttering only after i let off the gas.
I'm not sure about the anti-surge intake but that sounds interesting. I will have to do some research on it.
Anyone else care to chime in on the anti-surge thing.I think I'm running a heavier spring either 11 or 10 lbs. I have another black one laying around. I think black is at 6 lbs?
I am over mile high from sea level if that makes a difference.
Old Dec 21, 2016 | 12:54 PM
TexasLT4's Avatar
Sounds like rev hang, it's also a tuning based issue.. Check out this thread and see if it helps.
https://www.evolutionm.net/forums/ec...-evo-8-9s.html
youra6
Dec 13, 2016 09:00 AM
coastevo
61
Jun 12, 2011 07:38 PM
Frasch
29
Dec 25, 2010 12:56 PM
jam05pr
Jul 20, 2010 10:31 AM
