11.5 lift
Old Jan 18, 2017 | 06:13 AM
617APEXCT9A's Avatar
11.5 lift
Can you run 11.5 high lift cams on a stock block, or will it interfere with piston?
Old Jan 18, 2017 | 07:43 AM
TrendSetter's Avatar
timing is generally more important than lift. lots more duration can cause interference but depending on the setup advancing or retarding the cams can make the interference go away.
unless its way off you usually need to just put it together and see if it fits.
Old Jan 18, 2017 | 08:50 AM
LetsGetThisDone's Avatar
Yes you can. You just need appropriate valve springs and retainers. Guys run the GSC S3 on the stock bottom end routinely. Those cams have 11.7mm of lift.
evo8vz
Oct 12, 2016 01:42 PM
evovin
Driving Techniques
15
Oct 26, 2007 11:26 AM
mimmo124
Driving Techniques
Sep 25, 2003 07:32 PM
