Evo 8 - sometimes dies when coming to a stop, thoughts?
Old Feb 14, 2017 | 02:08 AM
GT45R Supra's Avatar
Welp, hopefully I can find someone local that has evoscan!
Old Feb 14, 2017 | 08:23 AM
llDemonll's Avatar
is your tial vent to atmosphere? if so, that's likely the issue unless you're speed density tuned which you don't mention.
Old Feb 14, 2017 | 12:14 PM
kaj's Avatar
kaj
That won't affect idle or cruising.
Old Feb 14, 2017 | 12:28 PM
meckert's Avatar
So what kind of intake is on this build? Are you VTA? Before you adjust anything
Old Feb 14, 2017 | 01:00 PM
llDemonll's Avatar
no but it can be related to the initial question of why it dies when coming to a stop
Old Feb 14, 2017 | 02:43 PM
kaj's Avatar
kaj
Not really, unless he is building boost, letting off the gas, and coming to a immediate stop. But it sounds like he's talking about normal driving. it doesn't take that long for the MAF to balance out.
Old Feb 14, 2017 | 02:52 PM
Evo VI.'s Avatar
The more likely scenario is your timing needs to be looked at in the low load areas as the cams may need a few degrees of timing in that area to avoid stumbling
Old Feb 14, 2017 | 04:39 PM
Tial & atmosphere - converted to speed density.
Old Feb 14, 2017 | 04:40 PM
Stock IM and TB.
Cam gear timing has been degree'd when motor was built.
Old Feb 14, 2017 | 04:41 PM
Correct - normal driving.
Old Feb 14, 2017 | 05:06 PM
Evo VI.'s Avatar
Apologies, I meant ignition timing in the map.
Old Feb 14, 2017 | 05:16 PM
No need to apologize when your offering help!
sgambino92
May 27, 2018 07:30 PM
moyassine
Jan 19, 2016 01:13 PM
MuasEvoIX
Apr 27, 2015 07:20 PM
Nelson999
Jun 19, 2012 08:28 AM
omniprobe
22
Apr 13, 2011 09:06 AM
