In need of help! Timing belt
Old Mar 5, 2017 | 02:45 PM
ajsegalZ06's Avatar
I'm in the process of putting the new timing belt on and I can't seem to get the can gears to line up to top dead center. Any trick to do this? Everytime I try to move them they bounced out of place
Old Mar 5, 2017 | 03:44 PM
lonestarr20's Avatar
Look up evomoto
Installing cams, that should give you insight
Old Mar 5, 2017 | 03:56 PM
asu11's Avatar
They're going to move because the valve springs are being pushed on. You can get cam lockers to hold them in place which is what I use or you can find another way to hold them while you install the belt.
Old Mar 5, 2017 | 04:02 PM
ajsegalZ06's Avatar
Have Cam lockers it's just a pain in the dick trying to turn the cam while putting that in.
Old Mar 5, 2017 | 04:18 PM
kaj's Avatar
kaj
It's definitely a pain in the butt. The tools to hold the cams in place are usually meant to install while the belt is on. Install, swap belts, remove. Since everything is moving, it's a bit tougher. I turn one cam, put the lock in, then use a wrench to turn the other. Having a second person is a huge help.
Good luck, man. It's the biggest pain in the butt, when it comes to putting our engines back together
Old Mar 5, 2017 | 06:35 PM
barneyb's Avatar
I remember having a couple box of end wrenches tied off with cord.
Old Mar 5, 2017 | 06:50 PM
kaj's Avatar
kaj
Doesn't work for those of us with IXs😕
Old Mar 5, 2017 | 08:30 PM
4b11slayer's Avatar
Set crank to tdc. Set belt on crank. Use paper clips to hold belt.
Put belt on intake cam while moving cam back with a wrench, ziptie so it doesnt move then set exhaust cam and put belt on.
Old Mar 5, 2017 | 08:31 PM
4b11slayer's Avatar
Have a buddy hold both cams on the marks with 2 crrscent wrenches is easiest.
Old Mar 5, 2017 | 09:22 PM
kaj's Avatar
kaj
Yup. When I do it on my own, the cams aren't on the marks. I put the belt on, one cam at a time. Everything is lined up, once I'm done.
not sure if that makes sense.
Old Mar 6, 2017 | 06:17 AM
ajsegalZ06's Avatar
So 8 hours later I got everything buttoned up. Fired it up and it sounded normal enough to my standards. Looked under the car and noticed oil was leaking from the bottom of the engine out of the lower timing cover by the crank ... idk why nothing can ever go smooth with my cars... From what I've read its most likely the tensioner bolts not being tight enough as oil flow behind them. Anything else I should check?
Old Mar 6, 2017 | 09:16 AM
4b11slayer's Avatar
could also be a leaking cam seal, oil pump, balance shafts.
Old Mar 6, 2017 | 09:24 AM
kikiturbo's Avatar
tensioner bolts not tightened..
Old Mar 6, 2017 | 10:05 AM
kaj's Avatar
kaj
Main seal would be the worst car scenario.
Pop the covers, it will be obvious. Good luck and get 'er done!
anthonypazsd
135
Apr 2, 2026 12:56 PM
evotris
29
Sep 8, 2013 07:26 AM
Robertv34
Aug 27, 2011 12:55 PM
PSG Evo
16
Feb 6, 2011 09:28 AM
anthonypazsd
Jan 31, 2010 03:01 AM
