Picture Request: OEM PS Hose Clip in Engine Bay
Old Mar 11, 2017 | 06:39 AM
EvoooB's Avatar
Hello guys, I'm in need of some help here with a factory clip that holds the power steering hose. It's the hose on the right hand side of the engine compartment that connects between the two aluminum hard lines for the return oil. The clip is located on the frame rail right next to the alternator and has one bolt that bolts it down to the rail and I think has a plastic round clip that opens and you put the hose inside and close the clip to secure it. If anyone could take a picture of that plastic clip and post it that would be great! Thank you in advance
Old Mar 11, 2017 | 03:11 PM
EvoooB's Avatar
Come on guys, 250 views and know one can go take a quick picture or two?!? Help a guy out!
Old Mar 11, 2017 | 03:37 PM
My clamp is disconnected due to my motor mount but all else is stock
Old Mar 11, 2017 | 05:50 PM
EvoooB's Avatar
That's almost perfect... I looking for a picture of the clamp on the return hose which I can kind of see in that picture. It looks like a white or grey colored clamp from that angle on top of the frame rail right across from the intake cam gear
Old Mar 11, 2017 | 06:13 PM
Are you referring to the AC lines vs PS?
Old Mar 12, 2017 | 06:10 AM
EvoooB's Avatar
Its def the PS hose, I added an arrow to your original picture of the clip I'm looking for. Thank you sir!
Old Mar 13, 2017 | 08:51 AM
EvoooB's Avatar
Anyone able to snap a pic of the clip I pointed out with the red arrow? I removed mine and I'm not looking for it and need to know what I'm looking for. Thanks
Old Mar 13, 2017 | 09:19 AM
Got me confused. I sent you a pic. Why would need another pic?
The part no. for the clip is: Mitsubishi MR133826
Old Mar 13, 2017 | 12:29 PM
EvoooB's Avatar
I cant see what it actually looks like from the top view you sent me... I need something down lower to see what the little ****er is shaped like to try and match it up. I tried using the P/N in google to get an actual picture of it but everything that comes up is one of those cheesy parts drawings lol
Old Mar 14, 2017 | 05:26 AM
Terror Rising's Avatar
Hopefully this helps.
Attached Thumbnails Picture Request: OEM PS Hose Clip in Engine Bay-img_20170313_183132764.jpg
Old Mar 14, 2017 | 06:27 AM
EvoooB's Avatar
Yes! That's close enough to allow me to match up and find the correct clip that goes there! I know it's a very simple and stupid clip, but I want to use the correct OEM stuff where it belongs. Thank you for the help!
Late Apex
May 22, 2026 03:23 AM
Evo11V
Mar 24, 2008 03:16 AM
David Buschur
61
Oct 5, 2006 10:33 AM
J8dailo
Jun 18, 2005 11:43 PM
1ChikDrivesStik
Lancer Engine Tech
Sep 21, 2004 01:26 AM
