Right Side Gauge Cluster Lights Out and Dimmer Not Working
Old Mar 15, 2017 | 09:50 AM
rosuegk7's Avatar
Hi all,
So I noticed when driving the other night that my gauge cluster doesn't illuminate the fuel or temp gauge. Only the speedo and tach are lit up.
I pulled the cluster to check the bulbs and when I moved the "burnt out" bulbs to a socket that was working, the bulbs all worked fine but if I moved a good bulb to the burnt-out side it didn't work.
Also, my dimmer switch doesn't seem to be working. Is this most likely a fuse or are their other gremlins going on?
I did search quite a bit but none of the threads I found seemed to detail exactly my problem.
Thanks!
Josh-
Old Mar 19, 2017 | 07:50 PM
J_Striker's Avatar
If you moved the "known good working bulb" to the non working spot and the gauges are still not lit up..... either the "wiring" under bulb (where it mounts to the cluster) is bad, or the cluster itself has an issue internally.
The wiring diagram shows that all the cluster illumination gets power and its ground from the same spots. Meaning, if it was a power or a ground issue, all of the cluster illumination lights would be inoperative.
As for the dimmer switch. It's nothing more than a variable resistance ground. If it isn't dimming, it's bad.
All of this should of course be checked out with a multi meter. You can find wiring diagrams for free at evoscan's website. I'm using Mitchel online diagram. Hopefully they are the same.
Good luck with your lighting issues.
Old Apr 19, 2017 | 08:28 PM
supak1111's Avatar
make sure the bulb is touching the connections on the board, its probably what burned out the first bulb in the first place
armatowa
Oct 13, 2012 10:43 PM
oldwheelieguy
Dec 6, 2011 08:11 PM
shroomster84
Jun 21, 2008 09:54 PM
RalliArtEvoVIII
Mar 10, 2005 10:43 AM
