Sputtering
Old Mar 23, 2017 | 01:55 PM
jrmav32's Avatar
Sputtering
Evo 8 started to sputter on w/ hitting boost. car recently got the plugs changed to a gap of .024, bpr8es. it backfires when i hit throttle and strt hitting boost and even when i brake boost
Old Mar 23, 2017 | 02:00 PM
tbaird58's Avatar
you look for boost leaks? if you ease into the gas how much boost builds before it starts to sputter?
Old Mar 23, 2017 | 04:11 PM
jrmav32's Avatar
ABOUT 7 to 8 lbs, high rpm range as well
jrmav32's Avatar
once it gets going it gets it though
Old Mar 23, 2017 | 06:34 PM
tbaird58's Avatar
im still leaning toward boost leak, or maybe you got a dead plug. ive never used the plugs you are currently using i always run with BPR7EIX. maybe try that.
Old Mar 23, 2017 | 09:56 PM
4b11slayer's Avatar
The plugs were changed how recent?
Speed density?
Old Mar 24, 2017 | 03:47 PM
jrmav32's Avatar
I'll do a boost leak Sunday and see how that goes.. yes speed density, a d plugs were changed this past Sunday and before that it never sputtered. Car has a freshly built 2.3 with a spoolinup ignition coil kit
Old Mar 25, 2017 | 06:44 PM
gsrboi80's Avatar
Put another set of plugs in it. Or gap the current plugs down a little to see if there is any change.
Is the AFR plugging dead rich when it breaks up.
Old Mar 26, 2017 | 07:01 PM
jrmav32's Avatar
Afr is 10.5 at 35lbs of boost. im going to do that tuesday when im off from work. ill take it to my tuner as well and see if theres anything up with the map
Old Mar 28, 2017 | 03:50 PM
jrmav32's Avatar
Bought some new plugs gapped them to .020 still does it.. going to gap them to 26 and see what it does
Old Mar 30, 2017 | 06:46 PM
jrmav32's Avatar
fuel regulator was fine, relay fuses to the double pumper were checked, boost leak was good, cam sensor was switched. what else can it be??? anybody who had the same problem on their evo get it fixed???? around 4k rpms its getting 2lbs of boost and its running lean..... oh and the wastegate was checked its fine as well
Old Mar 30, 2017 | 09:55 PM
RightSaid fred's Avatar
Photos of sparkplugs?
Old Mar 31, 2017 | 07:26 AM
jrmav32's Avatar
I'll get pics but they looked fine
Old Apr 1, 2017 | 11:25 AM
jrmav32's Avatar
yes car is speed density
jrmav32's Avatar
map sensor gone wrong or my ignition coils?
