Problems with 500hp walbro fuel pump
Old Mar 28, 2017 | 01:28 AM
EVOXTACY's Avatar
hi I have a Evo 4 with a 6 engine running on stock Evo 4 ecu and have just put a 500hp walbro fuel pump in and will hit 6,000 rpm and start struggling for fuel. Have 560cc injectors installed and a evo 6 ecu ready to be installed. Any ideas on what the problem could be?
Old Mar 28, 2017 | 06:01 AM
Biggiesacks's Avatar
Walbros are rated in liters per hour not hp, which one are you using?
Old Mar 28, 2017 | 09:05 AM
Ferp's Avatar
Are you running 560s on an Evo 4 ecu? Thats your issue. The Evo 4 ecu is scaled for the Evo 4 510cc that come stock. The car will drive like **** under load. You need to run the 6 ecu and injectors simultaneously, or run the 6 ecu and then scale it for 510s.
Old Mar 28, 2017 | 01:17 PM
EVOXTACY's Avatar
Originally Posted by biggiesacks
walbros are rated in liters per hour not hp, which one are you using?
255
Old Mar 28, 2017 | 01:21 PM
EVOXTACY's Avatar
I've been running the 560 injectors for a while now on Evo 4 ecu and standard fuel pump and was running fine (no power increase) until I put the walbro pump in. Cheers for the help
okevolutionVIII
Nov 26, 2012 11:19 AM
Carloverx
14
Dec 22, 2011 01:00 PM
turboDan
Dec 28, 2006 09:48 PM
DB8GSR
Aug 30, 2002 03:01 AM
