Idle insanely high?
Old Mar 28, 2017 | 01:42 PM
Evo47's Avatar
Idle insanely high?
So several days ago I configured the idle with the evoscan actuator, it was set low and car occasionally died. i set it right, with idle being at 850-900 when warm. Now recently i started the car again and the idle skyrocketed to 2000rpm, i thought it was because it was cold but on a warm engine it still idles that high. To get it to go down i would sometimes rev it and it drops to maybe 1350, which is still high. Any ideas what could be causing this?
Old Mar 28, 2017 | 02:18 PM
evo.matt's Avatar
Sounds like the IACV
Also have you tried adjusting the boss screw?
Old Mar 28, 2017 | 04:30 PM
Evo47's Avatar
Yeah i adjusted the biss screw, it was shortly after i fixed the idle that it started acting up, the issue came out of nowhere.
Old Mar 28, 2017 | 04:35 PM
pre2dat's Avatar
Not trying to steal your post... but I idle at 1200. Would this be considered high? Thanks, everyone's thoughts are welcomed.
Old Mar 28, 2017 | 06:10 PM
Evo47's Avatar
I would consider that high. Normal should be like 800-850, any lower and the whole car vibrates, at least in my experience
Old Mar 29, 2017 | 08:48 PM
pre2dat's Avatar
Hey, thanks. I'll talk to my tuner about it (also may adjust it with the bolts on the top portion of the throttle cable).
Old Mar 30, 2017 | 07:29 AM
DSMolition's Avatar
Did you set it the right way with evo scan or a mut tool?
1 check your BISS screw.
2 warm up your car use evoscan to "Activate the SAS MODE"
3 check the idle, if its less than 800 use the BISS screw to raise it a bit...
RalliArtEvoVIII
22
Apr 26, 2007 06:44 PM
lookslikeanevo
162
Nov 7, 2006 01:16 PM
jhanksevo
10
Oct 4, 2006 03:47 PM
HoLeeRay
26
Oct 11, 2004 06:41 AM
