Fuel pump problems
Old Apr 12, 2017 | 10:19 AM
Max Daniel's Avatar
Fuel pump problems
My Evo 8 had died on the freeway and got it towed out. No hoses lines pipes or fluids were out of place. Would start to crank. Power was coming in wanted to crank, but wouldn't. So I figured it was the fuel pump. Went a got a new fuel pump and installed it into my housing. Installed that and buttoned it up leaving the plate off in case I had to make adjustments. So I go to crank.... same story. Just rotates and won't start. Checked the fuses and lines and nothing. Tried cycling the fuel pump to no avail. Cannot hear the pump building pressure and seats are off in the back and cover for the housing is off.... I'm out of guess I need help. Any clue to what's happening or even a direction I can take this in.
Old Apr 12, 2017 | 10:33 AM
Biggiesacks's Avatar
did you try pulling codes?
Old Apr 12, 2017 | 11:25 AM
Pal215's Avatar
Try pulling fuel feed or return line and point it into a bucket. Have a friend try to start the car. Also take a look at your cam gear and crank timing marks to make sure they are not out of place.
CrazyLilPunk
Apr 24, 2016 04:17 PM
MisUnderStood
Dec 16, 2015 08:53 AM
Carloverx
14
Dec 22, 2011 01:00 PM
silverofs
May 1, 2006 09:50 PM
