Evo 9 stock turbo glowing red
Old May 6, 2017 | 02:12 PM
Dmx3alo's Avatar
Hey guys, so when cruising for 10 mins or so at any speed with rpm ranging from 2500-3500 with afr between 14.5-15.0 mostly 14.6-14.8 when my foot isn't moving around the pedal. I start hearing a whistle noise that gets louder when i get on boost and i stop to look under the hood only to find my turbo glowing red. This started happening after installing a resenator could that be the issue. What other things that might cause it that i could check.
thanks in advance.
Old May 6, 2017 | 02:24 PM
LetsGetThisDone's Avatar
Check the exhaust for restrictions.
Old May 6, 2017 | 03:59 PM
4G63_EVO's Avatar
The turbo glows red but not after some basic cruising, maybe the resonator you put is making really bad back pressure.
Old May 6, 2017 | 05:13 PM
RightSaid fred's Avatar
It's normal to see it glowing in the dark.
If it's glowing in daylight, there's probably insufficient timing advance.
Old May 6, 2017 | 05:25 PM
gsrboi80's Avatar
Does the car have a cat? If not I'd check the newly installed resonator as well
That is 100% not normal from a 10 min highway cruise
Old May 7, 2017 | 11:10 PM
Your whistling noise is another issue.
It might be a leak.
It might be a bent compressor blade.
If it's got a bent blade, it'll work harder to make boost so run hotter.
Old May 8, 2017 | 02:01 PM
4G63_EVO's Avatar
Another thing that could be causing whistling is a boost leak, I had a leak at my j pipe causing a nasty whistle/scream.
Old May 9, 2017 | 12:07 PM
Stark_Tech's Avatar
Is it possible for you to take that resonator back off and put something else on, perhaps whatever you took off? Just to see if it still does it.
Old May 9, 2017 | 12:08 PM
4G63_EVO's Avatar
I second this
Old May 9, 2017 | 01:49 PM
Dmx3alo's Avatar
i did that and put my old test pipe in which has no restrictions and the same problem happened, the thing is that the whistling noise happens and thats how i know the turbo will be glowing red, cause i kept checking
Old May 9, 2017 | 02:01 PM
4G63_EVO's Avatar
Might be out of balance
Old May 10, 2017 | 01:47 AM
Dmx3alo's Avatar
is that what might be causing the whistle?
also the whistle comes on as soon as i touch the accelerator
Old May 10, 2017 | 02:49 AM
4G63_EVO's Avatar
Its possible
Old May 10, 2017 | 10:25 AM
The turbo didn't suddenly go out of balance. Check for exhaust restrictions, and do a boost leak test.
Old May 10, 2017 | 12:38 PM
Dmx3alo's Avatar
It might be a leak.
but why would the whistling noise starting coming when the turbo gets hot if its bent wouldnt i hear it all the time cause if i stop for 5 mins and then drive it will take like 3 to 4 mims then the noise will come back again
