Evo 8 won't start
Old Jun 19, 2017 | 03:32 PM
Evo_8_power's Avatar
Evo 8 won't start
hey guys so today I ran into my first major problem with my 2005 evo 8 mr. I was riding down the highway and when I went to give it gas it wasn't doing anything. So I pulled over and it wouldn't turn over. The starter goes but it won't fire up. I got it to once and then it just died again. So I got it towed home and changed the fuel pump because I couldn't hear it whine anymore. But that didn't fix it. I was just wondering if you guys had any ideas on what it could be. The only thing I have done recently is take off the muffler. And also the car it mostly stock
Old Jun 19, 2017 | 03:42 PM
Biggiesacks's Avatar
no fuel pump coming on means no crank signal. Are you throwing any codes? Visually Inspect your crank sensor wiring etc.
Old Jun 19, 2017 | 05:11 PM
No codes on the dash. Don't have anything to scan it And what gets me is it will turn over sometimes. It just takes awhile and then when I give it gas sometimes it will rev. And sometimes it's spuddeds and hesitates.
Old Jun 19, 2017 | 05:40 PM
gsrboi80's Avatar
Check fuses?
Old Jun 19, 2017 | 06:22 PM
Bhsj13's Avatar
Originally Posted by gsrboi80
Check fuses?
^^maybe this.
Old Jun 19, 2017 | 06:35 PM
Yeah checked both fuse boxes
Old Jun 19, 2017 | 06:36 PM
Sorry guys forgot to add a few of the things I did. That was one. And then I just did a scan. It's just a cheap scanner for cars but it didn't pick up anything. And I don't have an evo scan yet
Old Jun 19, 2017 | 06:48 PM
gsrboi80's Avatar
You individually pulled each pertinent fuse and checked them?
Old Jun 19, 2017 | 06:58 PM
bad electrical contacts too maybe, check/clean your battery terminals grounds etc.
Old Jun 19, 2017 | 08:57 PM
No I didn't check all the fuses I can do that. And the battery was good because I had to disconnect to to change spark plugs. Because I thought maybe it was spark.
Old Jun 19, 2017 | 10:43 PM
EVILutionVIII's Avatar
Veteran: Air Force
Are there any other lights on the dash? My alternator just recently went out and I experienced similiar symptoms.
Old Jun 21, 2017 | 03:21 PM
http://youtu.be/SUFURgjrLPg
here is a video of the problems. When it starts to die that is me giving it gas
Old Jun 21, 2017 | 05:21 PM
Bhsj13's Avatar
GOT IT! i had the same problem. i bet it is the MAF sensor. it wont throw a code unless it is completely done for.
Old Jun 22, 2017 | 07:29 AM
Sweet man. I went ahead and bought one. I hope you are right! I'm ready to have her up and running again
Old Jun 22, 2017 | 07:57 AM
llDemonll's Avatar
you can just unplug it and see if it runs any better before you buy one...
