Evo 9 Fuel Cutting
Old Jul 11, 2017 | 09:07 PM
jheff's Avatar
Originally Posted by butte
OP, just curious if the symptoms seem to vary based on throttle position? I had the same issues with Tephramod whenever I held TPS around 100% and I'm curious to see what helps your issue
Are there any problems that you can't fix with an FPR and a fuel pressure gauge?
When the car goes lean, changing the throttle does not stop the issue. I have only recently experienced the issue when cruising or going from a stop, but that has also been the majority of my driving. I have never experienced the issue when at WOT or near it, but that could be just luck
Old Jul 12, 2017 | 05:05 PM
jheff's Avatar
okay, so my Tactrix cable came in the mail, and I have evo scan set up.
I will be getting logs tomorrow or later tonight, what values should I log?
Thanks!
Old Jul 13, 2017 | 12:35 PM
jheff's Avatar
Originally Posted by Klaiceps
Looks like you are on SD and if so then you must be running an aftermarket MAP sensor. If your MAP sensor is an Omni 4 bar MAP sensor, try swapping it out for a known working one and report back.
So it looks like you said it correctly. I just plugged in my comp into the car and checked the CEL that tripped the other day. P0107 MAP sensor low voltage. Now could the car not trip the CEL and still have issues, Im placing the order for the new MAP sensor as I write this, but could it really be that simple?
Old Jul 13, 2017 | 02:24 PM
Klaiceps's Avatar
Yes. When I first came across this issue I had no CELs pop up. The faulty MAP sensor had me chasing my tail for a while. It wasn't until I used Evoscan and saw that my manifold pressure reading was erratic and incorrect even with the engine off. Once I changed out the sensor the car fired right up.
Old Jul 14, 2017 | 12:59 PM
4G63_EVO's Avatar
Does this only apply to speed density
Old Jul 14, 2017 | 01:11 PM
kaj's Avatar
kaj
No.
Old Jul 14, 2017 | 01:40 PM
4G63_EVO's Avatar
Originally Posted by kaj
No.
Ill see if I can pull up my readings
Old Jul 16, 2017 | 03:03 PM
jheff's Avatar
The sensor has been ordered. I forgot to mention that the old MAP sensor was also an OMNI 4 bar, how long are the lives of these sensors? I have no clue when mine was installed because it has been on since I have bought it, but is there any maintenance or something that I could do to make sure i dont run into this issue again? Thanks!
Old Jul 16, 2017 | 04:04 PM
4G63_EVO's Avatar
Ive seen multiple threads with them going out, I think its just something that needs to be changed as regularly as it gives out, I also think they will warranty it for you!
Old Jul 16, 2017 | 04:48 PM
Klaiceps's Avatar
Mine lasted a little over a year. However a friend of mine had his go out as soon as 3 months. It's a crapshoot however Omni has supposedly revised the MAP sensors to be more durable. My friend changed his out for the new revised one and so far no problems. I think he's been on this MAP sensor for 6 months so far. As for me I've since switched over to an AEM 5 bar MAP sensor.
Old Jul 16, 2017 | 08:23 PM
jheff's Avatar
I saw, if there is a warranty however I should probably hop on that. Hopefully this will fully solve the issue!
Old Jul 21, 2017 | 09:52 AM
Klaiceps's Avatar
Any updates? Did getting a new sensor solve the problem?
Old Jul 21, 2017 | 01:36 PM
jheff's Avatar
I have been driving the car to make sure, I dont want to post something and then it goes bad again. But so far no issues, It seems to have totally solved the problem.
I want to get more miles on the car before I say for sure!
Old Jul 21, 2017 | 08:58 PM
jheff's Avatar
Okay so I drove up to english town, drag raced the car, and drove back to Surf City. Car drove way smoother before and there was no issues that I could notice. The car seems to be perfect now and there seems to be no more issues!
Thanks everyone for your help!
evo88dany
Feb 22, 2016 07:30 AM
needsboost
Sep 20, 2012 12:02 PM
nonojoe66
10
Jul 14, 2008 05:27 PM
criptballer
Jun 12, 2008 10:32 AM
mis4tun81
45
Sep 13, 2003 06:46 PM
