Fuel cutting at WOT
Fuel cutting at WOT
bought my Evo 8 about a month ago now. it has an MBC, intake, hard pipes, and cat-back.
in any gear, from 4900+ rpm it is hitting a hard fuel cut and stuttering all the way up the RPM range. ONLY at WOT, i can be at 17-18psi and it is smooth as butter, but as soon as it goes WOT it stutters.
Could this be from the previous owner messing with the MBC and therefore the boost tables? I have checked all the clamps and hoses over once, but just the fact that i bought it from a young person who told me "you can just twist this knob and bam, you get more power", makes me think he went wild turning the knob like a strippers tassles.
I emailed the company that installed the MBC and tuned (Touge Factory) to see if they keep a log of work and what the car was tuned for.
for the time being, would it be best to just adjust the MBC down to decrease boost?
thanks!
thanks!
Im having the same issue but as soon as i hit full boost/load. Violent shaking front the front. Like Im hitting a wall.
Part throttle pulls cleab to redline. I think its in the tune.. needs to be adjusted. I have a mew one Im going to put in tonight.
Going to swap plugs, boost leak test, and look into the front o2 sensor. Keep me updated on your car amd i will do as well.
unfortunately i received an email back from Touge factory this morning. they did install an MBC and coils, but never did a tune. so as far as i know, there is currently not a tune on it, which is quite aggravating. Luckily i ordered my tantrix cable already. I will be getting new plugs this weekend as well.
is there a reason it doesnt have a code for misfires triple L?
very good question... this idk i did a bit research and these engines recommends ngk spark plugs gap at .20-.25 and at the time i had new champion iridium plugs gapped at .27 and started backfiring like crazy...my tuner told me to go back to stock plugs.... forgot the part number but they are ngk iridium and everything went back to normal
needsboost
Dec 10, 2012 04:34 PM
ThePresley
Dec 4, 2011 12:07 PM
