Overcharging issue after clutch install
Old Aug 16, 2017 | 02:15 AM
Project_Broke's Avatar
Im about to rip my hair out.
Just finished with a clutch install, started the car and noticed the battery and brake lights on. Proceeded to check connections and found everything tight. Scan tool reads 14.5v but volt meter on battery reads 15.3+. So I determined the voltage regulator must have gone belly up.
Pulled the alternator, it was a duracrap from the previous owner, this further solidified my theory. Put a new OEM alternator in, and same issue. Evoscan logs show 14.5-15v where they used to show 13.8ish.
I have checked to make make sure I didn't pinch a wire or something when installing the clutch, and I can't seem to find any other explanation after searching other than the alternator. I don't think it's likely that both alternators have the same issue.
any ideas are helpful and appreciated.
Old Aug 17, 2017 | 03:47 AM
In case anyone else has an issue similar, my solution:
The "S" terminal wire (3rd one down when the connector is plugged in) seems to be the reference voltage for the ECU to determine regulation. My wire was outputting 3 volts lower than the actual battery voltage causing the ecu to compensate. I bypassed the wire directly to the battery and my problem was fixed. 14.2V charging. It must have been pulled or broken somewhere slightly. I didn't find any issues visually checking the wire.
Old Aug 17, 2017 | 06:55 AM
4b11slayer's Avatar
You didnt forget the ground on the bellhousing?
Old Aug 17, 2017 | 07:01 AM
No, I actually ran a new one, as well as the one on the intake manifold thinking they were the issue.
I replaced the wire exactly how it was, and it's fine now. So it was shorted somewhere.
Old Jan 12, 2021 | 04:06 PM
SHAN7S's Avatar
Do you have any pic for which s terminal that you’re talking about because I have the same problem
Old Jan 12, 2021 | 04:09 PM
SHAN7S's Avatar
Old Jan 12, 2021 | 04:38 PM
hutch959's Avatar
he is just talking about the terminal that plugs into the alternator
hutch959's Avatar
so basically... you had a wire broke in your harness somewhere...
Old Jan 12, 2021 | 05:10 PM
SHAN7S's Avatar
I bought a new battery harness from STM Just installed I and this is what’s happening to me
jwick76
Lancer Troubleshooting
Nov 17, 2014 06:56 AM
eusgen
Lancer How Tos / Installations
Jun 25, 2012 06:44 PM
Dowve
Oct 12, 2011 12:52 PM
Kevin Knight
Jan 14, 2008 03:15 PM
Mikey52
Sep 17, 2007 04:58 PM
