RPM needle issue
Old Aug 16, 2017 | 07:23 AM
R4PT0R's Avatar
RPM needle issue
Hi guys,
I'm having an issue with my ct9a where the rpm needle will bounce around, the engine idles and revvs fine but the tacho is doing its own thing. Has anybody had this issue,
I'll attach a vid of my car doing it. I was stationary and in neutral in the vid.
Cheers
Old Aug 16, 2017 | 11:15 PM
4b11slayer's Avatar
Might be a cluster mechanism issue. Substitute good known cluster
Old Aug 16, 2017 | 11:21 PM
R4PT0R's Avatar
Thanks for the reply, is this something I can change on my current cluster as I don't really wanna change the whole thing. Also this issue only started since I have been cleaning things in the engine bay.
Is there a rpm sensor or a vacuum line that reads the rpm?
Old Aug 16, 2017 | 11:43 PM
Jp7's Avatar
Jp7
I've seen this before on cars that have bad alternator diodes. The AC frequency from the alternator can affect the speed sensor if it absorbs it as "noise".
Disconnect your alternator control wire and see if it still does it. Your car will not charge the battery but who cares if it's only for testing.
Old Aug 16, 2017 | 11:48 PM
R4PT0R's Avatar
Thanks for the reply, sorry I forgot to add that this is an intermittent issue and doesn't happen all the time.
Cheers
Old Aug 22, 2017 | 07:13 AM
TariqEvo's Avatar
if u have a friend with an evo, try switching clusters.
atleast the result will point u to a more specific direction
Old Aug 22, 2017 | 07:26 AM
R4PT0R's Avatar
Ok so an update for you guys, i have changed the cluster to a known working one, and the problem still persists.
Don't Evo's get the rpm in this order, crank and cam sensor - Ecu - Dash, i wasn't aware that a speed sensor sent rpm readings, i could be wrong though.
Old Aug 22, 2017 | 07:48 AM
TariqEvo's Avatar
okay, thats great news coz clusters cost a lot.. try this 👆🏻?
Old Aug 22, 2017 | 08:15 AM
R4PT0R's Avatar
ok very noob question incoming.
but what is an alternator control wire? it may be referred to something else where im from.
Old Aug 22, 2017 | 11:08 AM
Jp7's Avatar
Jp7
There are several wires on the alternator. The control wire is not the big beefy one. You should have a little plug, temporarily disconnect it and see if you get the symptom while it's disconnected.
Old Aug 29, 2017 | 05:57 AM
R4PT0R's Avatar
So I tried unplugging the alternator and tried changing the speed sensor in the gearbox and got nowhere, any more ideas?
Old Aug 29, 2017 | 06:19 PM
barneyb's Avatar
Connect an external tach to the tach port in the under hood fuse box and see the same fluctuation occurs.
Old Aug 30, 2017 | 12:27 AM
RightSaid fred's Avatar
The signal comes from the coils.
Old Sep 7, 2024 | 08:35 AM
Sky45's Avatar
Forgive me to revive this post. I got exact same problem, anyone knows the solution?
Old Sep 8, 2024 | 04:50 AM
R4PT0R's Avatar
Hey mate, it ended up being a dodgy Scotch lock in the ECU wire for the rpm, I just looked up a wiring diagram from m for my Evo I can't remember if mine is 3 or 4 plug but you should be able to find either. Haven't had an issue since.
pierceman
Dec 13, 2006 10:45 PM
bishiboy
Apr 14, 2004 06:36 AM
The EVO
15
Nov 28, 2003 11:48 PM
danc
Jan 30, 2002 04:40 AM
