Valve Cover -An fittings question
Old Aug 27, 2017 | 06:52 PM
Kraise's Avatar
Hey guys!
I have been messing around with my evo quite a bit so I'm sorry for these questions that should be fairly easy to find, but I searched everywhere and couldn't get an answer.
If my valve cover has a 5/8 hole would I be able to run a -6 an line from that even though its made for a -10 fitting? I have a catch can that has -6 fittings and I don't really want to modify it just to run a -10 line
Thanks guys
Old Aug 27, 2017 | 08:11 PM
evoix10's Avatar
http://www.streettunedmotorsports.co...r_fittings.htm
Is this what you're looking for? I'm guessing you're talking about the rear fitting?
Old Aug 28, 2017 | 05:03 AM
Kraise's Avatar
Hey, basically the valve cover I bought doesn't have the pcv valve so its just a big hole If I buy the -10 bigger fitting, I won't be able to run my current catch can with the -6 fittings; is it possible to get that part with the rear half that would fit into a -10 hole but the other half as a -6 fitting
On that link, the -6AN Front has a skinnier rear half which lets it fit into the smaller hole, basically I was looking for a -6 AN that will fit into a bigger hole
Old Aug 28, 2017 | 12:51 PM
Terror Rising's Avatar
Does the valve cover still have the bushing the PCV fit into or has it been removed? If it still has the bushing all you need is a -6 rear fitting.
Old Aug 28, 2017 | 03:31 PM
Kraise's Avatar
No it doesn't have it, came without it
Old Aug 28, 2017 | 03:57 PM
LetsGetThisDone's Avatar
PCV-Valve cover grommet:
http://www.streettunedmotorsports.co...t_mn158504.htm
6AN PCV fitting can be found here:
Old Sep 5, 2017 | 05:35 PM
punk3rz's Avatar
Veteran: Army
Get some 5/8" to 6an fittings and you'll be able to run them no problem.
4G63 DSM
14
Sep 24, 2014 08:34 AM
nightwalker
28
Jun 18, 2012 09:17 PM
VTEC Killer
Jan 26, 2009 11:02 AM
