would this work
Old Aug 27, 2017 | 11:38 PM
Jonno99's Avatar
would this work
just been blowing off the LICP hose lately so I thought this might work, I have liquid nails some sand paper onto the inside of the T clamp and going to put back on
I used high strength liquid nails and sand paper with cotton material on the back for extra strength.
I also roughed up the back of the stainless so the liquid nails will grip the clip
Old Aug 28, 2017 | 02:16 AM
Johnboy1065's Avatar
maybe try a different t-bolt clamp?
Old Aug 28, 2017 | 07:25 AM
llDemonll's Avatar
The t-bolt clamp gripping the silicone isn't the issue, it's the silicone sliding off the intercooler pipe.
put hairspray on the pipe then slide the silicone coupler on if you haven't done that already
Old Aug 28, 2017 | 08:11 AM
Biggiesacks's Avatar
problem with sand paper is its paper. Especially considering this is your LICP its probably not going to survive the elements all to well.
+1 on hairspray, also maybe try actually rough sanding / scuffing your LICP where the coupler slides over for increased friction.
Old Aug 28, 2017 | 10:39 AM
meckert's Avatar
^^^^this.
Old Aug 28, 2017 | 12:47 PM
A more permanent trick, is to weld, small water drop size **** on the pipes circumference, just below of the clamp location to keep the clamp in place
Thats what was done to my blow-off hose to intake pipe
Old Aug 28, 2017 | 04:29 PM
Jonno99's Avatar
I've left the clamp for a few days to cure, the sandpaper is cotton backed quite tough the glue is like a rock, I'm going to rough up the rubber and metal pipe and use hair spray, I'm going to give it everything I got captain. This clamp ruined my last track day it aint going to do it again
Old Aug 30, 2017 | 03:24 PM
evolord21's Avatar
Veteran: Army
+1 on hairspray. Pantene is what's I use and I've never had a pipe blow off after that switch
Old Aug 30, 2017 | 04:44 PM
Jonno99's Avatar
like this?
https://www.target.com/p/pantene-pro...ph1|51176498|2
Old Aug 30, 2017 | 05:27 PM
4b11slayer's Avatar
Try a smaller clamp and or get the pipes bead rolled.
Old Aug 31, 2017 | 07:28 AM
llDemonll's Avatar
Originally Posted by Jonno99
yep; any hair spray will do but gold color always adds HP
Old Aug 31, 2017 | 10:44 AM
silent_white's Avatar
google vice grip bead roller, you're welcome
RavSpec
EvoX 'For Sale' Wheels / Tires
10
Dec 14, 2014 07:53 AM
RavSpec
Evo 'For Sale' Wheels / Tires
Dec 13, 2013 03:48 PM
TeKiZeRo
For Sale - Wheels / Tires
13
May 29, 2007 07:30 PM
