2.2slr efr9180 1.45 ar
Old Sep 2, 2017 | 12:18 AM
moyassine's Avatar
Post 2.2slr efr9180 1.45 ar
hows it going y'all. this is my 5th evo i've owned, recently traded my twin turbo duramax for it from a local friend that took care of it. ive owned it for maybe two month now. any ways it came with few bolts ons and made 500whp. had 272 cams, gt35 top mount, fic 1450 injectors, e85 etc,.
couple weeks ago i got called out by a bully with a 1000+ hp hellcat.. so the build started and looking forward to let him see my taillights. so far these are the parts/secs i got
block:
. English racing 2.2 block
. 10.5.1 wiseco 1400hd pistons
. r&r aluminum 156mm rods
.k1 billet crank shaft
.er spec bearing and clearances
.er spec oil pump gear
.buschur baffled oil pan
.all new block/head
.modified lower case timing cover by er
.arp main studs.
.new oem timing belt.
head:
.arp custom age 625+ head studs
.gsc s3 cams.
.gsc 5057 valve spring
.gsc ti retainers
.ferrera valve seats
.ferrera 1mm over valves.
.super tech valve seals.
.aem adjustable cam gears.
fuel:
.in tank aeromotive 340 fuel pump
. vi engineering surge tank
. double bosh 044 fuel pump
.-8 feed and return line
.aem fuel rail
.aem fpr.
.e85
.fic 2150 injectors.
.curt brown polished and ported intake
.75mm throttle body.
drive train:
..jacks oem rebuilt 5 speed trans
. exedy twin disk clutch
.refreshed tcase.
.solid driveshaft carrier bearing.
hot parts,turbo,inter-cooler:
.efr 9180 1.45a/r twin scroll divided
.pressure release valve block off plate.
. twin turbo smart 40mm waste-gate.
.Hayden Wilson ff facing turbo manifold
.hood dump exhaust and dump tube.
.2.5 inch inter-cooler piping
.ams 3.5 inch race core inter-cooler.
. tial bov.
. speed density
.efr turbine wheel seed sensor.
. aem wide band.
The list just goes on and on. hoping to get 800-850 whp, its been a rough couple weeks on the wallet since 90% of these items were purchased brand new within one week. i will keep you guys updated as the build goes threw, hoping to get the car rolling by couple weeks.. i will upload pics once i get on my phone. feel free to ask any questions
moyassine
Sep 2, 2017 12:29 AM
Moore Auto
Evo X Dyno Results
19
Sep 4, 2015 01:53 AM
GotWheelHop
Dec 10, 2014 03:40 AM
Moore Auto
Evo X Dyno Results
16
Apr 23, 2014 03:02 PM
GotWheelHop
Nov 26, 2013 04:22 PM
