HELP evo 9 vibration noise
Old Sep 11, 2017 | 12:35 PM
AlexAL's Avatar
Please help if you know what this is! I have a evo 9 with a 5 speed swap but the 5 speed was done a long time ago. recently i had a leak from my transfer case so i took it to a local shop and they fixed the leak. as soon as i drove off with the car, i started hearing this vibration coming from the rear end. It vibrates for a second, stops for a second, then starts again for a second, and stops again for a second. basically every other second, it vibrates. Its not a super loud vibration. It vibrates while im driving. If im driving 40mph, and put it in neutral, it still does it so its not influenced by rpm. nothing vibrates when the car isnt moving. Any input is appreciated thank you
Old Sep 11, 2017 | 09:56 PM
Jonno99's Avatar
did they pull your TC?
Old Sep 12, 2017 | 04:14 PM
AlexAL's Avatar
They did not. Have you heard anything like this before?
Old Sep 12, 2017 | 05:18 PM
Jonno99's Avatar
sounds a bit like drive shaft vibration, you might need to get under and check to see if anything is lose. If the rear seal on the TC was leaking they would have pulled the drive shaft out.
Old Sep 13, 2017 | 01:41 PM
barneyb's Avatar
Yeah, what was leaking?
Old Sep 15, 2017 | 11:03 AM
AlexAL's Avatar
Performance shop found what it was, the drivers side rear wheel bearing.
Old Sep 15, 2017 | 05:08 PM
barneyb's Avatar
Glad you found it.
elhuberto
Sep 13, 2013 04:45 PM
SeanM505
Jun 7, 2013 06:10 PM
Stan C.
10
Jun 26, 2012 05:29 AM
EvolutionTime
33
Feb 9, 2011 07:28 PM
evoracerx
Oct 12, 2006 06:28 PM
