Rough hp estimate
Old Sep 17, 2017 | 05:18 PM
AWD Problems's Avatar
Veteran: Army
Rough hp estimate
New to the evo game and i am just wonder with all the mods how much hp should i be looking at end goal would be around 500whp
Stock block
Gcs 2 cams
1050x id injectors
Walboro 450
Fp red JB
Custom intake w/ maf
Maperformance manifold
44mm wg
Old Sep 17, 2017 | 06:15 PM
RazorLab's Avatar
If only there was an entire thread on this forum dedicated to FP Red dyno results?
https://www.evolutionm.net/forums/ev...ts-thread.html
Old Sep 17, 2017 | 07:34 PM
4b11slayer's Avatar
Your gonna need e85 and about 30 psi to hit 500
Old Sep 18, 2017 | 12:18 AM
evo8vz's Avatar
Seen re make 380 on pump all the way up to 500
depends on your fuel and quality of tune
cams/porting and ect...its impossible to tell you.
however on q16 or e85 you can make 525+ on that set up
your injector set up i would never run e85 on 1050 with a red minimum 1300 and might fall short....your best bet is q16 and boost
Old Sep 18, 2017 | 06:07 PM
EnergyBoosted's Avatar
Yeah, to reach that goal you are gonna need some bigger injectors and some fuel better than 93 pump. E85 should get you there.
Old Sep 23, 2017 | 12:51 PM
Jmills's Avatar
Couple of people from Data I have collected
Gilbert was on 93 oct, the rest were e85.
Kenrick was on a dynojet vs mustang for the others
Old Sep 27, 2017 | 12:29 PM
blackline's Avatar
5 Year Member
defiantly going to need bigger injectors and e85
AustinB768
43
Jun 8, 2012 05:24 AM
alpha812
Sep 3, 2011 02:01 AM
whitedemon
Jun 4, 2011 12:29 PM
Raistlin
11
Feb 26, 2011 01:52 PM
