Coolant everywhere
Old Mar 4, 2018 | 08:12 PM
Hunterjames700's Avatar
Coolant everywhere
So here's the deal, the other day I opened my hood to show a friend my engine bay and I noticed a small amount of coolant on my transmission. I cleaned it up and checked it again that night after putting about 70 miles on it and there wasn't any coolant. I then checked again the next day after about 30 more miles and there was coolant again. So I cleaned it up and I've been doing that every couple days since, cuz I've been to lazy to look for the leak.
Well then hen last night I raced a fiesta ST and after two races I could smell coolant pretty bad and saw a small amount of smoke coming from my hood vent. Opened my hood and there was a lot of coolant... like everywhere. I got a pressure tester today and put it to 20 psi and waited about 15-20 minutes and couldn't find any leaks. It is wet where my head meets my block but honestly my whole bay is pretty wet cuz it's hard to clean so idk if it's leaking there or not.
My main question is can coolant be leaking from my head externally but not internally? And if it is leaking could it spray all over the bay from my head?
my oil is fine and my car doesn't burn any coolant. I would also think if it is leaking from the head it would just seep coolant not spray.
And my car never overheated
thanks!
Old Mar 4, 2018 | 08:13 PM
It also seems like it must only do it when I'm beating on the car, so high rpm's
Old Mar 4, 2018 | 08:53 PM
2006EvoIXer's Avatar
What radiator hoses do you have and what clamps are you using?
Old Mar 4, 2018 | 10:00 PM
Oem but I definitely don't think it's leaking from there. The car didn't leak coolant when it was stock hp but it was tuned last week and is now 400hp. Don't know if that has anything to do with it.
Old Mar 4, 2018 | 10:08 PM
Using gloves, try squeezing the hoses when engine is hot. Mine leaked at thermostat so swapping a worm clamp solved the problem. If no luck, wrap each hose with separate cloth and anything you can think of with a separate cloth. Drive around hard and check each cloth for coolant.
Old Mar 5, 2018 | 06:36 AM
That's a great idea man thanks! The only thing I'm worried about is if it's coming from my head I don't wanna make it worse.
Old Mar 11, 2018 | 08:22 AM
SaltySilver's Avatar
do you have a different turbo setup? I had a coolant leak recently in a similar spot it ended up being a bad banjo bolt on my turbo, pulled the turbo swapped all banjo bolts, put new copper washers and have zero leaks now, hope this helps
Old Mar 11, 2018 | 10:34 PM
codgi's Avatar
Had an aftermarket water pump fail recently but that leaked very little coolant while doing so. What sucked was that it was less than 6 months old
Old Mar 11, 2018 | 10:55 PM
That sucks! The labor is the same as changing the timing belt. What brand did you use?
Old Mar 11, 2018 | 11:48 PM
zuppy's Avatar
Did you check the coolant lines on the TB? I had a small coolant smell for the past few weeks and noticed it was leaking very little from the bottom one.
Old Mar 12, 2018 | 08:39 AM
Biggiesacks's Avatar
How old are all the hoses? If you are passed your scheduled replacement you should just replace all of them, and probably solve the issue in the process. Another thing to look at is the radiator itself, the plastic end tanks are known for cracking/separating from the aluminum core and leaking.
Old Mar 13, 2018 | 08:34 PM
codgi's Avatar
It was a gates. Previous 2 OEM ones were fine when replaced at 6 years and 5 years respectively. Back to OEM.....
Old Mar 13, 2018 | 09:03 PM
I thought about saving a few dollars. Glad I decided not to take a chance with non-OEM. Thanks for confirming the quality difference.
Old Mar 17, 2018 | 05:43 PM
ScoobySport91's Avatar
Veteran: Marine Corp
I notice coolant on top of my transmission and found out it was leaking on the plastic ends of the radiator
Old Mar 17, 2018 | 06:11 PM
RightSaid fred's Avatar
All these problems usually happen due to over pressurisation of the cooling system in turn caused by a bad headgasket.
"creeping death".
After you fix the radiator....a hose pops.
Then another one pops....fix that too.
Then a heater hose pops....fix it.
Then the heater core pops.
But it's an old car and the hoses are old...lol
Or worded slightly differently.........if the headgasket is perfect, the cooling system will never over pressurise and therefore the radiator won't fail.
Nor any of the hoses.
Just common sense?
Johnboy1065
12
Jan 28, 2008 01:38 PM
use2vtec
16
Jan 19, 2008 11:45 PM
turboDan
Aug 6, 2007 12:48 PM
xenoturkey
May 9, 2006 01:57 PM
EVIL_EVO_VIII
49
Oct 7, 2005 05:53 PM
