Service Engine light Flashing while using launch control evo 8
Old Jun 3, 2018 | 01:38 AM
RaceRusk7's Avatar
My Service engine light flashes while using launch control on my evo 8. I checked the car for codes and the only code that came up was over boost condition of turbo charger. Service engine light does not flash unless using launch control. What is going on with the car?
Old Jun 3, 2018 | 03:45 AM
Bladey's Avatar
It iwas tuned using tephra v7 it could be the fact its detecting knock.... Best thing to is log using evoscan and check if you are getting knock. if you are get it retuned!
Old Jun 3, 2018 | 09:48 AM
RaceRusk7's Avatar
Okay thanks. I’ll check into it. If the car is getting knock on only launch control do you think any damage has been caused or does it just need re tuned? From what I hear the car can be set up to detect knock even a smaller number. If the scale was 1-10 the car could be tuned to detect knock at say a 1 and could not be dangerous or could be a 10 and be very dangerous. What do you think?
Old Jun 15, 2018 | 06:57 AM
RS200's Avatar
You only get a flashing CEL when you have a misfire that puts raw fuel into the catalytic converter, which causes downstream explosions that can destroy the cat. Launch control is a deliberate misfire to put unburnt fuel into the manifold to cause downstream explosions. Makes perfect sense to me.
RaceRusk7
Jun 4, 2018 08:54 PM
RaceRusk7
Jun 3, 2018 11:52 PM
moreno78065
Jun 18, 2015 07:20 PM
slosuby
Sep 6, 2014 04:00 PM
AoyamaJPN
Aug 24, 2009 12:00 AM
