When looking to buy should I avoid this?
Old Sep 4, 2018 | 09:45 PM
Momentum1's Avatar
It seems like every single evo I look at “needs a tune”. Which I’ll be the first to admit I’m not as mechanically incline to a turbo car as the next may be but I’m learning slowly. Is this a cop out for bigger issues and I should stray or is it something I shouldn’t be concerned with? Also how is the car going to act “needing a tune” sluggish? Or it all varies due to the mods taken off to sell or added?
Old Sep 5, 2018 | 05:53 AM
You should arrange to have the pre-buy inspection done by a shop that is EvO knowledgeable. Compression test, leak down test & an overall inspection of the engine, suspension & drivetrain
Any EvO that has been modified, should be evaluated by a tuner to ensure all the parameters are in a safe zone
Old Sep 5, 2018 | 08:53 AM
llDemonll's Avatar
IMO yes, it's a cop-out for a larger issue. unless the owner says something like "installed full exhaust but was never tuned, car is still on stock tune". that's not an "issue", but more of a recommendation
people who are like "car has s2 cams, full bolt ons but needs a tune so that it runs well"....skip it. if the person didn't have the care and upkeep to get a car with all that stuff tuned means they likely also didn't take care of the car in many other ways as well.
no guarantee on either of these, just guess-work at how the car was treated.
Old Sep 5, 2018 | 09:50 AM
barneyb's Avatar
I have a hunch you're seeing cars that have had aftermarket parts removed in order to make the car seem more stock like and valuable.
Old Sep 5, 2018 | 05:26 PM
hutch959's Avatar
"needs a tune" = Doesn't run right.
could it be just the tune? maybe.... maybe not.
Old Sep 5, 2018 | 10:06 PM
kaj's Avatar
kaj
IMO: "Needs a tune" = "Needs something to run right, but I can't figure it out". Nobody I know builds a car then sells it before having it tuned. That just makes no sense.
Old Sep 7, 2018 | 07:51 AM
SW20Mike's Avatar
Veteran: Air Force
Needs "just a tune", haha, yeah I'd walk away too.
Old Sep 7, 2018 | 09:08 AM
heel2toe's Avatar
I read the "just needs a tune" the same way that someone will say "AC just needs to be recharged". Sorry but not buying it. run don't walk!
Old Sep 7, 2018 | 08:32 PM
kaj's Avatar
kaj
"AC just needs recharge" = short for "Figure an AC compressor, condenser, drier, and expansion valve into your budget. May as well add in extra for lines, just in case. Oh.. then the vacuum/test and refrigerant. All because I thought it was a good idea to remove AC for going to the local drag strip.. but I just put it back in, so you are good to go. I hope I didn't dry out all the seal, but I probably did".
Old Sep 13, 2018 | 01:00 PM
my-wrx-broke's Avatar
I'm selling my Evo8 and I don't have "need a tune" in the listing. But I feel like anyone that buys it is going to take it to someone they trust and retune it.
Old Sep 13, 2018 | 01:55 PM
kaj's Avatar
kaj
As long as it was tuned when you had it ,should be fine for the seller, assuming you didn't swap out parts.
Old Sep 16, 2018 | 09:18 AM
MattJC's Avatar
Have a tune factored into the price. So if it still doesn't run correctly, it's not under your name after the tune
Old Sep 16, 2018 | 09:56 AM
kaj's Avatar
kaj
What?
Old Sep 25, 2018 | 06:10 AM
Project_Broke's Avatar
Originally Posted by kaj
What?
I think what he is saying is factor in paying for a tune before buying, if it doesn't fix it, don't buy it. If the person doesn't want to have the car tuned for free before selling, obviously they know it's not just a tune.
Old Sep 25, 2018 | 06:22 AM
kaj's Avatar
kaj
Fuuuuck that.
