What are your Evo goals for 2023?
Old Oct 23, 2021 | 04:43 AM
  #76
pjmeunyc12's Avatar
I got my 9 MR tuned at destination performance in Orlando last week, next up for 2022 is new clutch. Any recommendations on clutch replacement? I'm running 361/375 stock turbo with bolt ons
Old Oct 27, 2021 | 08:53 AM
  #77
schuhie's Avatar
What's the plan for the car? Daily at roughly that power level, an ACT HDSS is tough to beat. Shooting for a turbo upgrade and more power, a twin disc like the Exedy or the new ACT one might be a good choice.
I personally ran the HDSS up to 500whp/400wftlbs and it was great. After a motor build and turbo upgrade, I smoked it at about 600whp/500wftlbs and moved to a Exedy twin and like it a lot as well.
Old Jan 9, 2022 | 10:35 AM
  #78
Bfitz's Avatar
Veteran: Marine Corp
Get the Evo2 bodywork all done and repainted/ carbon fiber roof installed by spring 2022. I will be happy.
Old Jan 9, 2022 | 10:58 AM
  #79
TimInselman's Avatar
Max out the stock turbo on E. then decide on a Turbo upgrade.
Old Jan 9, 2022 | 11:13 AM
  #80
asayamalaka's Avatar
reinforce CF section of spoiler with foam and rods
custom tuning display from zada-tech.com
Old Jan 9, 2022 | 09:17 PM
  #81
Pal215's Avatar
2022 Goals
1. Rebuild the OEM 5 speed to have as a spare.
2. Replace my FP Black with the fastest spooling turbo that will make 500hp on E85 with a 2.3L. (Anybody know if the FP54 GREEN, MHI TF06-18K, or the 71HTA Super Core has ever gotten there? Any other suggestions? Torque welcomed.)
3. Get a set of wheels and upgrade to Ohlins DFVs (probably not gonna happen)
4. Convert my three gauges into a single multigauge. Looking at options such as PLX and Zeitronix for a more subtle look than a three gauge A pillar pod.
5. Get a more stock feeling clutch so that my wife can drive my car too. She hates the ACT 6 puck sprung lol ( I don't blame her).
Old Jan 10, 2022 | 09:30 AM
  #82
huzzle101's Avatar
Get her running again, its been almost a year of me taking too long to get things done and changing my mind on stuff.
New Clutch i think is needed.
Start buying parts for an engine build ( maybe not)
Old Jan 10, 2022 | 03:35 PM
  #83
CurseDSM's Avatar
1. Get my car back from Slowmotion with a full tune.
2. Make 1000whp on some sort of dyno.
3. 10.99 pass on street tires.
4. Install driveshaft and driveshaft loop.
5. Get t case upgraded.
6. Get trans upgraded.
7. Get to run test and tune at the shootout.
8. And last but not least and most importantly whoop XrogueXs *** at the shootout with his fp black setup. (Love ya buddy)
Old Jan 11, 2022 | 11:29 AM
  #84
Abacus's Avatar
1) Go to TX2K and run the sequential car
2) Get the Paint corrected on the fp red car
3) Full engine catch pan
4) Road course with the fp red car
Old May 21, 2022 | 08:26 PM
  #85
nightowl1985's Avatar
5 Year Member
After going without a scratch from Hurricane Laura and Delta of 2020. My goal for my Evo for 2021-2022 has been building to be reliable 900whp.
2.0L
Wiseco 1400HD 9:1 comp 85.5mm .0045 PTW 18 top/22 bottom ring
Manley 300M Turbo Tuff I-Beams with King XPC STDX .0027 bearing clearance
Main studs/stock crank King XPC STD .0030 bearing clearance
ACL Oil Pump with ER oil pump gear
FTY rear BS to ORB adapter for crank case breather can
Sheepey Race Oil Catch Can off the valve cover.
Head-
Skunk2 Intake Manifold with throttle body
GSC S3 cams
GSC No-Tick Lifters
Supertech Dual Valve springs
GSC +1 Intake and Exhaust (Super Alloy)
GSC Stopper guides
Kiggly HLA
TMZ Performance head stud shouldered dowels
Turbo-
DrivenFab Forward Facing V-band hot parts
Boostlab BL67X (67mm) DBB with 0.83 A/R V-band housing
Fuel-
Flowed and Matched 2200cc injectors
JMF Fuel rail
Bulletproof Racing fuel pump hanger with single 450
Nuke Performance FP100X regulator
Nuke Performance 3L Surge tank with 2 AEM 400Lph "044 Style" pumps
Stainless .064 wall pipe with matching ID with 10AN and 8AN linking fuel rail to rear fuel system.
Engine Management and sensors
Emtron KV8
Ohm Racing Engine Harness
VariOhm Eurosensor 8bar MAP
Bosch ADV wideband
Rife Sensor Triple Pressure Sensor ( 200psi Fuel/150psi Oil/100psi Coolant)
Flexfuel
Old Sep 20, 2022 | 09:26 PM
  #86
iilliilliill's Avatar
New clutch
Brake upgrade
Tune
Old Oct 5, 2022 | 02:59 PM
  #87
LuisVPR's Avatar
Talking Restore an Evo 8 back to stock
Bought a 2005 Evo 8 last week. Plan to restore it back to stock.
It was parked out in the sun for 7 years. The paint is absolutely ruined. Getting that fixed/repainted in November.
Old Oct 5, 2022 | 03:24 PM
  #88
Alright Luis @LuisVPR Keep us posted on your project & great to have you on board w/us
Cheers, Joe
Old Feb 17, 2023 | 11:22 AM
  #89
krys88's Avatar
2.0L
Head-
GSC S3 cams
GSC No-Tick Lifters
GSC Stopper guides
Kiggly HLA
Turbo-
Fuel-
JMF Fuel rail
Emtron KV8
Bosch ADV wideband
Flexfuel
How is your engine holding? And what power are you making?
Old Feb 18, 2023 | 12:31 AM
  #90
5 Year Member
I have had a few setbacks and working out fresh build bugs, but it should finally be running soon.
