Fuel cut??? Boost cut ?? Idk..
Old Feb 21, 2019 | 10:38 PM
Evoguy!123's Avatar
So I've been dealing with this problem for 1 month and haven't stepped on the gas because of this issue, when i accelerate in high rpm i get this cut between 5k - 6k around there and then bounces right back up, replaced spark plugs, and ignition coils and wires. Any tips ?? Can't be the tune, when i got it tuned i didnt have this issues. Help?
Old Feb 21, 2019 | 10:48 PM
Wicked_X's Avatar
What size spark plug gap are you running, and how much boost?
Old Feb 21, 2019 | 10:49 PM
Evoguy!123's Avatar
I'm not sure what gap they are, but i read that they were pre gapped from Mitsubishi?? Im doing 20 psi but turned it down to 18, and still have the same problem.
Old Feb 21, 2019 | 10:57 PM
Wicked_X's Avatar
I would check the gap and make sure it isn't anything crazy. When I bought my car it had the stock tune, but had insane hesitation/break up from the spark plugs having like a .036 gap. Stock boost levels.
I would also do a boost leak test for sure to eliminate that.
Which spark plugs are they by the way?
Old Feb 21, 2019 | 11:15 PM
Evoguy!123's Avatar
Will do, and They are NGK copper (BPR8ES)
Old Feb 22, 2019 | 01:15 AM
Fox_IX's Avatar
Take a datalog through your pull. That'll give a much better idea of what's going on.
Old Feb 22, 2019 | 10:06 AM
Lumpy Sticks's Avatar
5 Year Member
Are you still running the stock intake box and snorkel?
Old Feb 22, 2019 | 10:51 AM
barneyb's Avatar
Mitsubishi doesn't make or gap spark plugs. Years ago, when I had a DSM, people on the DSM forum were writing that NKG plugs were made and gaped for our cars. Then someone pointed out that the same plug was used in Honda lawnmowers.
Old Feb 22, 2019 | 11:02 AM
Wicked_X's Avatar
Last time I went to buy some BPR7ES, the lady at oreilly thought I was crazy, telling me my car uses iridiums and these plugs are for a lawnmower
Old Mar 3, 2019 | 07:01 PM
Evoguy!123's Avatar
Okay so im on 20 psi, how much do i gap my spark plugs ?
Old Mar 3, 2019 | 07:24 PM
Not sure what EvO you have but heres the 9 spec
Old Mar 3, 2019 | 07:27 PM
Evoguy!123's Avatar
got an evo 8, getting these damn fuel cuts that iv never had before. Also like in 3k rpms sounds like it bogs out
Old Mar 3, 2019 | 07:50 PM
Wicked_X's Avatar
If I were you, I would invest in some datalogging tools so you can know what is actually going on. Do you have a wideband o2 installed?
Evoscan and a tactrix cable are your friend.
Just gap it down to like .022 and see if issue is still present, then reassess.
