What is required to get a evolution IV 500 to 600 whp?
Old Apr 6, 2019 | 10:31 PM
EmpyreanM's Avatar
I'm curious on the cost and if 600 whp is viable or if 500 whp is more suitable for day to day life.
Old Apr 7, 2019 | 05:11 AM
Hello / Welcome
Speaking in total generalities: 500 Dyno Jet WHP is on the very aggressive side for a stock block motor. 600 DJ WHP is beyond what is considered safe WHP on the stock block. Stock block WHP is best suited for the low to mid 400's (Dyno Jet measured)
Trying to achieve those higher WPH no.s (above 600) is an investment for sure ($8 to $10K USD minimum for a built short block, turbo & labor) (dependent on if you build & install yourself vs professional build & install)
Old Apr 8, 2019 | 09:53 AM
Grimgrak's Avatar
A tune and a jug of torco for everytime u want to switch
Old Apr 8, 2019 | 10:04 AM
RS200's Avatar
The Evo 4 is not doing 500 on stock block. They barely hold together at stock power.
Old Apr 8, 2019 | 10:05 AM
Mauricio Evo IV's Avatar
Well, you need a forged engine... Turbo kit, FP Black or 6266 turbo, a Transmission rebuild kit, LSD for transfer case and an Evo 8-9 rear diff with axles.
Old Apr 8, 2019 | 01:06 PM
frsh92laser's Avatar
Check book with alot of checks.
Old Apr 8, 2019 | 07:17 PM
Teal2nnr's Avatar
Depends on what type of fuel you're trying to get it done on.
The question is so broad, and that power can be achieved so many ways. I suggest you start researching and getting ready to open up your check book.
Old Apr 11, 2019 | 02:08 AM
EV09AWD's Avatar
5 Year Member
If money wasn't an issue what should be done to the lower half of the engine to support 600hp?
Old Apr 11, 2019 | 06:42 AM
@EV09AWD Im not the engine expert but simple things like this: (English Racing specs 2.0L)
  • Eagle Rods
  • Wiseco HD Pistons
  • 9:1 / 10:1 Compression Options
  • OEM Polished Crank
  • ER Balance Shaft Delete
  • ARP Main Studs
  • ACL Rod,Main & Thrust Bearings
Or bigger pwr goals here: (English Racing specs 2.2L)
  • 2.2 "RACE" SLR 800WHP
  • Carrillo Rods + CARR Bolts
  • Wiseco Custom Anodized Pistons
  • K1 Billett Crank
  • ACL Bearings
  • ARP Main Bolts
Old Apr 11, 2019 | 04:53 PM
japspec's Avatar
  • Eagle Rods
  • Wiseco HD Pistons
  • ARP Main Studs
  • K1 Billett Crank
  • ACL Bearings
  • ARP Main Bolts
Yep English racing is the route to go. Thank god you didn’t mention buschur racing unless the op wanted to throw money away lol.
Old Apr 11, 2019 | 05:36 PM
RS200's Avatar
A basic forged engine build would be just fine, it doesn't have to be exotic or by a big name.
That list also leaves out all of the supporting stuff (turbo, manifolds, IC & piping, fuel, clutch, tuning, etc).
