Evo 8 Steering rack problem
Old Apr 28, 2019 | 04:04 AM
Biro's Avatar
Heya!
I’ve dropped my subframe due to engine renovation, and now putting it back together. But I’ve came across a problem, when I removed the “hub” from the steeringrack (down at the pedals) I had to use a little force with a crowbar (I marked it and removed the m8 bolt first)
but now I can’t get it back on for some reason, feels like it’s to short, I can get it on those upper splines but can’t get it to slide down to the lower ones. Anyone got any ideas?
Kind regards, biro
Old Apr 28, 2019 | 05:22 AM
@Biro Heres the manual for the EvO9. There are some cautions noted that maybe the cause of this issue
See here:
File Type: pdf
Old Apr 28, 2019 | 06:15 AM
Biro's Avatar
Thank you for that manual, I’ve already looked trough it tho but I don’t get any more clever haha. I haven’t released the tilt mechanism anyhow, but it seems like I have to get that clip off to manage to get it on? Or am I wrong, since I had to use some force to get it off :/
See here:
Old Apr 28, 2019 | 11:07 AM
barneyb's Avatar
The clip the factory used is a two man install I learned the hard way. I substituted a worm drive hose clamp.
Old Apr 28, 2019 | 12:55 PM
deylag's Avatar
Using a pair of pliers clamp the clip on the steering column. Then pull out the inside shaft till it mates up with the steering rack shaft.
Old Apr 28, 2019 | 05:28 PM
hutch959's Avatar
yep... this.
if you hold the clip, open, it takes the tension off the splines and will let you slide it down
Old Apr 29, 2019 | 12:39 AM
Biro's Avatar
Thanks once again guys!
It worked great and i manage to get it back on.
But i noticed that my steering gear box is off alignment
can turn like 1 turn to the left, and 2 or more to the right. Anyone got any idea how to measure the center to get the alignment “ok” until I can drive it to a shop for a proper 4wheel alignment?
Originally Posted by hutch959
yep... this.
Old Apr 29, 2019 | 09:37 AM
barneyb's Avatar
Get the front wheels as straight as possible, then pull and do again with steering wheel straight. Hopefully, when off you left the steering wheel locked. Otherwise, you may find the clock spring breaks and needs replacement (no horn).
