Evo 9 4g63 ticking noise diagnosis
Old Oct 24, 2019 | 06:37 AM
aquaplane's Avatar
I've decided to change the balance shaft bearings, ordered some new acl balance shaft bearings. Before I take off the timing belt & front case, is it going to be possible to change the bearings while the engine is in the car and with the crankshaft still installed?
Old Oct 24, 2019 | 07:54 AM
Chrispy0530's Avatar
Originally Posted by aquaplane
I've finally gotten back to the evo. I've installed new gsc lifters and the issue persists.
I've just checked all rod bearings and there is no play in them. Stumped!
Balance shaft seems to have a bit of play.. Would it be safe to remove balance belt on the timing side and run car without to determine if that is the knock?
It sounds very silly, but did you bleed the new lifters? I swapped my head when I was having similar issues, and after a new short block, and a low-mileage head with new lifters the noise was still there. Once I removed the lifters, bled them, and re-installed. Poof, noise was gone.
Old Oct 24, 2019 | 08:32 AM
aquaplane's Avatar
Yes, I did. Filled lifters with oil in a syringe and released the inner bleeder ball a few times whilst pumping the valve and getting the air out through the side hole. I've done this to all 16 before installing them.
There is a bit of play in the left counter shaft, towards the front case side. It makes a similar metal to metal knocking sound so I've organised new balance shaft bushings - left and right. I thought I could confirm it is indeed the balance shaft bushings, by removing the balance shaft belt on the timing side. That would mean I'd have to drop the sump again, reseal & another bottle of oil. According to the service manual, removing the balance shafts to replace the bearings isn't any easier..
Old Dec 6, 2019 | 08:07 PM
krys88's Avatar
Did you fixed it?
Spanishevo
24
Feb 15, 2011 12:09 PM
Oki Panoki
Nov 14, 2007 06:51 PM
badboybr09
May 4, 2007 12:22 PM
ries
17
Jul 15, 2005 01:52 PM
TRDHarrier
Jun 26, 2005 04:16 PM
