Knock noise on Acceleration
Old Sep 27, 2019 | 10:19 PM
WelDun1's Avatar
I have a 2005 Evo 8. When I bought the car, I had a New Tranny installed & then a New Clutch about 8 months later. Tranny has about 35k miles & clutch maybe 15k. English did the work.
Every time I accelerate from a stop or let off the gas then accelerate again I hear a loud knock coming from somewhere close to the firewall maybe?
It's not a deep solid steel sounding knock, but more of an aluminum hollow-ish knock, if that makes any sense?! I feel like I can't explain it accurate enough. It started around the time that English installed my Clutch, and has recently gotten worse. I've tried checking as many bolts & brackets in the tranny/differential tunnel area that I could see, but no luck. I was thinking maybe a CV knock, or maybe a tranny mount? I've also read that the brakes somehow make a knock sound?
Anyone else experience this? I've read a few other threads, but none of them sound like my problem.
I really need to figure this out ASAP tho, so any ideas would be awesome?
Old Sep 28, 2019 | 10:17 AM
barneyb's Avatar
Check around the center differential hump. There's some piping in that area that could be interfacing with the transmission.
Old Sep 28, 2019 | 10:46 AM
WelDun1's Avatar
Thanx @barneyb I'll look into that.
Another thing I've noticed is that I can sometimes feel it in my pedals.
I don't think this is the issue, but I was told by English that an exhaust w/o a flex joint can cause vibrations & knocks. I don't have any sort of flex joint, just straight piped all the way back.
I'm grasping at straws at this point. It would be so much easier if I could just get it up on a lift!
Old Sep 28, 2019 | 11:06 AM
WelDun1's Avatar
Maybe if I got a list of ALL possible causes for knock/clunk sounds in the "Firewall area" I can't start with some good ol' Process of Elimination
Old Sep 30, 2019 | 06:55 AM
kyoo's Avatar
check the power steering line - that was mine.
Old Oct 4, 2019 | 10:02 PM
WelDun1's Avatar
I will definitely check that.
What kinda of sound was it making, when did you hear the sound, and how did u fix it?
While searching for the problem, I did find that the tie rod boot was slipped off of the rack. Idk if that would cause the sound I'm hearing tho, u would think if anything, it would cause a sound when steering from side to side.
My noise is happening when I hit the gas. Almost always a single "knock", but occasionally it'll be 2 knocks, almost like it's bouncing off whatever it's hitting.
EvocentriK
14
Jun 19, 2013 08:05 PM
miller121mx
30
Sep 8, 2011 12:41 PM
sdfontanini
Sep 9, 2009 08:09 PM
JohnBradley
Oct 17, 2008 07:23 PM
ant_turbo
Sep 25, 2006 03:08 PM
