AYC clutch delete to instal CuscoRS diff
Old May 23, 2020 | 06:16 AM
Lerio's Avatar
Question AYC clutch delete to instal CuscoRS diff
Hi everyone
I would like to know if you could indicate me, if there are discussions on the removal of the AYC system from the EVO VI GSR differential case,
to be able to mount a Cusco RS diff and eliminate the pump and accessories.......into the GSR case diff
and if there are tutorials on the work to be done.....
many thanks regards
Lerio
Old May 23, 2020 | 09:53 PM
EVOFans's Avatar
You are better off finding info from lancerregister.com for AYC and pre EVO VIII
You are better off going with RS differential than to convert AYC differential to Cusco LSD, the AYC differential casing is weaker and will fail under higher HP application.
Old May 24, 2020 | 01:23 PM
RS200's Avatar
When they were still making parts, Ralliart made a conversion kit to put the mechanical diff inside the AYC case. I haven't seen one of those kits in years, however. There are diffs to upgrade the AYC setup, but they still depend on hydraulics and none of the RS-style diffs will install directly. To totally eliminate the hydraulic setup, you will need an entire RS differential setup (diff mounts, diff, axles, etc).
jameswwt
37
Mar 7, 2016 08:02 AM
RoryE4
Sep 21, 2015 05:40 PM
MitsiMadness
Jun 26, 2011 07:55 PM
rpece
Sep 24, 2009 10:04 PM
TrinaBabe
Feb 17, 2005 12:22 AM
