Drivetrain Shaft Issue Evo 8
Old Jun 22, 2020 | 03:28 PM
thatredevoXIII's Avatar
Exclamation Drivetrain Shaft Issue Evo 8
Well I found the issue to why my car chatters when decelerating lol.. driveshafft bearings went bad and chattered.. now I just want to see, from what it looks like in the picture the parts I need to fix this issue. Here is what I have found on STMTuned. Would you guys go STM or OEM.
-Driveshaft Carrier Bearing Support Bushings (8-Piece Set of 4 Bushings)
https://stmtuned.com/collections/mit...pport-bushings
-DriveShaft Center Support Bushings
-Driveshaft Boot Repair Kit
https://stmtuned.com/collections/mit...oot-repair-kit
-Driveshaft Center Bearing Insulator
https://stmtuned.com/collections/mit...ring-insulator
Old Jun 22, 2020 | 04:46 PM
hutch959's Avatar
could always just look for a used drive shaft
Old Jun 22, 2020 | 07:13 PM
Biggiesacks's Avatar
thats the lobro joint. If its been without grease for a while there is a chance its toast.
Old Jun 22, 2020 | 08:13 PM
LetsGetThisDone's Avatar
Yeah if it's to the point it's making noise, it's smoked. The boot kit isn't gonna fix it
Old Jun 24, 2020 | 07:14 PM
I see.. so I may as well change out the whole driveshaft... darn. Where would you recommend a new OEM driveshaft be bought from?
Old Jun 24, 2020 | 07:39 PM
Would you think following this thread may help? https://www.evolutionm.net/forums/ev...oint-wear.html Found someone else having same issue
Old Jun 24, 2020 | 08:46 PM
Yeah, I mean if you have the time and capability of tearing it down and measuring everything out etc then no harm in that. I found my seal blew and that the joint had worn, I was able to pick up a good low mileage driveshaft for a very good price so I just went that route. If it happened again I would probably just pick up a 2 piece driveshaft. They are a nice upgrade and are more serviceable.
Thoe99
16
Jan 6, 2023 10:15 AM
randomdriver
Jul 24, 2014 06:49 AM
AWD Motorsports
EvoX 'For Sale' Engine Internals and Drivetrain
150
Sep 23, 2011 09:27 AM
AWD Motorsports
Evo 'For Sale' Engine Internals and Drivetrain
400
Oct 29, 2010 08:43 AM
2SloEvo
Jun 7, 2006 03:16 PM
