Down for the umpteenth time...
Old Jan 4, 2021 | 04:49 AM
Amandaraejean's Avatar
Originally Posted by hutch959
what kind of log is that? have you got a stand alone?
im a little confused by the whole scenario here... IC pipe pops off and tune changed to raise boost... then ic fixed and boosted 42psi.
anyway.. good luck with it.
yes its a stand alone.
Old Jan 4, 2021 | 02:09 PM
LetsGetThisDone's Avatar
Originally Posted by Amandaraejean
its on e85. i managed to upload the log. it was a pain to figure it out. not friendly at all...
the clamp wasn't tight on the coupler under the turbo... it popped off on the first pull.. didn't notice until after session when it logged 10psi. tuner thought 10psi was wastegate, so he upped boost to make 24psi, i then fixed the coupler. and since he upped it to 24 and the boost leak was fixed.. it spiked to 42. i didn't tell him about the coupler popping off cause im an idiot and missed it. hopefully you can read the log. lmk
That is not a "small" boost leak.
I wouldn't trust that piston anymore, at the very least it needs to come out and polish out those divots/sharp edges from the bits bouncing around and inspect the rod bearing and crank.
Old Jan 4, 2021 | 08:58 PM
piston is already out. new one is in. no damage to walls. getting spare head decked and built while replacing valves on damaged one.
Old Jan 5, 2021 | 06:35 AM
colo_evo's Avatar
I would sit down with the tuner and discuss all the modifications and your expectations the car. Sounds like you had a major disconnect while going through the tuning process which lead to a faild engine. The tuner should have had safeties setup and you shouldn't have been driving like you were when it failed. This situation was completely avoidable.
Old Jan 5, 2021 | 10:37 AM
def plan on going through everything with the tuner to avoid another mishap. thanks for the suggestions..
TommiM
Sep 27, 2013 11:34 AM
SparkTech
Jul 25, 2011 07:42 PM
haze1995
Northwest Region
18
Dec 8, 2007 12:35 AM
Handmemyarms
May 2, 2006 03:59 PM
