Quick question!
Old Jan 9, 2021 | 11:27 PM
MrEvo9Mong's Avatar
Quick question!
Anyone know if i can run a stock oem
map for a 9:1 cr 2.0L evo 9 block and not have issues?
location is in CA so it’ll be running on ACN 91 until it clears state reff fyi.
thanks in advance.
Old Jan 10, 2021 | 08:48 AM
LetsGetThisDone's Avatar
It'll be close enough to drive it to get inspected if you're running stock cams.
Old Jan 10, 2021 | 10:18 AM
MrEvo9Mong's Avatar
I see. It will be on stock cam but the block will be a freshly built block. Hopefully all goes well...
Old Jan 10, 2021 | 10:35 AM
Biggiesacks's Avatar
As long as you aren't throwing any Codes, all your smog monitors are ready/pass, everything notable between the airbox to the cat is stock (intercooler & Ignition mods are ok but that's it no intercooler piping), and you aren't blowing any smoke out of the exhaust you should be good.
Old Jan 10, 2021 | 01:11 PM
MrEvo9Mong's Avatar
What about the ecu part? I heard it doesn’t have to be calibrated by the dealership. As long as its noted by a shop that its been corrected as should. Any knowledge on this?
Old Jan 10, 2021 | 02:38 PM
If you were flagged for ECU tampering you have to prove it was corrected. Otherwise it just needs to be a completely stock calibration to pass.
Old Jan 10, 2021 | 03:57 PM
MrEvo9Mong's Avatar
Right on, definitely got flagged for ECU tampering lol thanks man. Hopefully this 9:1 engine can run good on the stock tune so i can get it to pass.
Deanpug
Aug 19, 2010 05:34 AM
