What's causing this??
Old May 13, 2021 | 01:29 AM
SUPER fly TSi's Avatar
Does anyone know what's causing this and how to fix it?
Old May 13, 2021 | 04:01 AM
Evo9_Dubai's Avatar
I am guessing a leak from the hose?
Otherwise do you notice you are pushing coolant into the overflow after boosting?
To put your mind at ease, I would definitely burp the radiator and check if bubbles keep popping. So you can catch a problem early on if it's a blown head gasket.
Old May 13, 2021 | 07:03 AM
Biggiesacks's Avatar
looks like its time to replace your hoses. Get new clamps while you are at it.
Old May 13, 2021 | 07:57 AM
There nothing in the overflow after boosting
Old May 13, 2021 | 08:11 AM
RobbieOh's Avatar
5 Year Member
I'm still new to Evo world, but in my Honda days, this was indicative of excess pressure in the system due to a failing head gasket. The compression would push coolant out the reservoir or the weakest clamp/hose.
Old May 13, 2021 | 08:17 AM
The cap is suppose to be the weak point in the system. It could be stuck, but this hose is toast regardless. The hoses are part of the maintenance schedule. I'm guessing these are overdue.
Old May 13, 2021 | 08:37 AM
barneyb's Avatar
Check if the metal neck has corrosion or deposits on its exterior. If it does then a new hose will also leak. Clean it up to a smooth metal surface.
I'm not sure what you mean by " There nothing in the overflow after boosting". If you mean the reservoir is empty, that's not right.
Old May 13, 2021 | 03:11 PM
Evo9_Dubai's Avatar
Like others have suggested, just check the hose and replace it if necessary.
I would, just for peace of mind, burp the radiator and make sure there is no head gasket problem.
I had a similar issue and diagnosed a blown head gasket very early. Replaced it and all was good to go.
babyburner
North Texas Evo Club (NTEC)
10
Jan 5, 2011 08:43 PM
Xolition
May 7, 2008 11:30 PM
MRedition
Aug 23, 2006 08:20 PM
modelchris
Jun 6, 2005 08:11 PM
