Evo GeneralDiscuss any generalized technical Evo related topics that may not fit into the other forums.
Please do not post tech and rumor threads here.
A true 8 wing has carbon fiber inserts on the pillars. No way they replaced the wing w/an 8
Yes, add the G-flap if you like. its not going to do anything you will notice & we understand its just a looks thing for ya, so no problem adding that at all
Your thread brought up memories for some of us.
8 wings look like this:
Thanks! I had no idea the sides were different between the 8 & 9. Mine are CF so looks like I have the 8 spoiler.
ugh.more issues to address you guys sure the IX wing can be disassembled? i will try to put an aluminum pipe/bar in there. I just cant go with the full race car wing
Its can be disassembled easy, this would forsure solve the problem other people had with the 9 wing failing however I have been using mine with a gurney flap for a long time at high speeds against very powerful winds and its never failed. Also have the vortex gen.
probably down slope winds? I'll add this to my to-do list. Thanks
Originally Posted by WRC-LVR
Quite a few folks have had the 9 wing fold up under aero load. You could install a brace under it in the middle to fix permanently, But it wouldnt look stock. you might disassemble the wing and inject expandable foam into it but tricky for full fill.
If you are after the looks as primary and secondary some effect for the aeros, i'd get an 8 wing and add the gurney to it. Save the 9 wing for when you sell your car.
BTW i made my gurney from aluminum angle for my 8 MR wing on my 8 MR and used 3M tape extreme to hold , bent it to fit the slight rear radius of the wing. 3/4 in wide and 1/2 inch tall. No issues up to 130 mph. Tested by pulling as hard as possible to try to budge it. stayed put except when prying very hard with screw driver under it and that took quite a bit of prying
YMMV
Alrightey gents, The wing is off the car. I can't figure out how to disassemble this, Any tips? Thanks
If all goes well, is there anybody that sells a riser for this wing? would be cool to make it work a bit more
I also wonder if the construction of the gurney flap itself contributes to wing failure. MinusPrevious, I noticed yours was some cheap ebay material just taped onto the wing. If it were a strong, composite carbon flap I wonder if this would have added strength to the wing and kept it from failing.
Im sure that trunk lip may have contributed, but i know now the 9 wing really does not belong on a proper track day EvO. I certainly learned a few things tracking the EvO.
Weak links (mechanically or aero) are certainly exposed
well OK. I got it separated I used these wedge tool thingers. I tried separating the CF but it looks to have a couple of studs inside ok off to Lowes tomorrow and get some aluminum/whatever tubes & expanding foam. I actually have really thick galvanized wire so that a lighter option. Should I put supports (ex:5mm tubes) on the leading and trailing edges OR 5mm trailing edge + 12mm tube somewhere in the middle? I also plan to make a 2" riser later
Well done! If you can take a few detailed pics of the CF wing ends that might help those who attempt this.
I would think if you can just fill the wing w/some high density poly U foam & make sure it packs in full. Dont allow the foam to stretch out too much as that weakens the foam structure. Keep in mind there are many different foam formulations. Structural foam vs home insulating so please check around (I would use a min of 4lb density foam). There are spray foams & there are foams you can mix on your own.
That foam should be enough to withstand track speeds? But adding those tubes, as you noted, could add some structural strength if they were placed tightly in the wing (but, likely not needed for sure)
In any event you are doing something most EvO owners have never done so this is unchartered territory in my book. This should be its own forum post if you complete it to your satisfaction
As you can see, the trailing edge is pretty thin so I dont think any foam can add much strength to that. I see foam to be more of an adhesive that will "triangulize" several points on the CF, so light foam would be ok (as long as it adheres to the CF) and just enough to keep "tubes" from rattling. Note that I'm raising the wing eventually so I need something stronger than evo8's
I might visit Academy Sports to see if there are any material I can use
Thanks
Nice pics & thanks. I understand better how the wing was constructed. If you want, you can make a new thread to support this tear down & re-construction? Its up to you or i will change the title to this thread so it can be found in a search
