Evo 7 GT-A Vibration problem
Old Apr 25, 2022 | 09:34 PM
OGHalo's Avatar
So I drive a '02 Mitsubishi Lancer Evolution VII GT-A, when ever I put my vehicle in drive and at idle the vehicle vibrates and at times the idle would jump up and down once and a while and at cold start the vehicle almost die when the idle drop, I did heard my exhaust making noise for a few seconds. I checked the engine mounts and I don't see any issues or problems with them, I changed the spark plugs, clean the throttle body, iacv, and maf sensor, I also had the vehicle retune to Canadian 94 octane. I can't be sure what else that could be the problem any ideas?
Old Apr 26, 2022 | 08:29 AM
slocho's Avatar
Any time you have idle issues, a boost leak test is the first thing to check. If you havent had the car long, an engine health check you also be good to check such as compression test and leakdown check. An A/F gauge also helps, if you dont have one, its a good idea to install one.
Old Apr 28, 2022 | 06:20 PM
OGHalo's Avatar
I just completed the compression test, I only warm the vehicle up for 5 mins once it got to temperature, I did not open the throttle when turning the key over I didn't realized that step until I read one of the forums, I have the photo in order from #1 to #4 it ranges anywhere from 153-158psi, #1: 158psi #2: 156psi #3: 153psi #4: 155psi. I'm not sure what's the average psi rating these motors should be to confirm the engine is heathy.
Old Apr 28, 2022 | 06:28 PM
slocho's Avatar
Ive found different brand gauges read different PSI. But its a good sign that all 4 are colse to the same.
Did you get a chance to do a boost leak check?
There are some threads about people having idle issues due to failing idle control valve. I would read up on that as well. Having an auto trans might make it more challenging to find the issue.
Old Apr 28, 2022 | 06:32 PM
OGHalo's Avatar
I haven't done a leak test because I'm not sure what I would need and where to start. I've checked my iacv not to long ago and it looks in good shape but can't tell if there's anything wrong with it. I'll definitely take a look
Old Apr 28, 2022 | 06:38 PM
slocho's Avatar
The biggest challenge in a boost leak check is having a compressor that will supply enough airflow. There is several how-to threads. I made my own tester or you can buy one but itll be useless without a compressor. Bottom line is you can't skip any diagnostic steps as basic as they might be otherwise you might be wasting time and money. Worst case, check what you can. If nothing else, a competent shop you trust should get to the bottom of your idle problem.
Old May 1, 2022 | 04:50 PM
RMILtd's Avatar
If this doesn't get figured out andf you're ever in BC with the car we run a JDM specialist shop out here.
Dealt with a few Evos in the past few weeks, 11 years total evolution experience with Evos
AlwaysinBoost
Feb 17, 2011 06:51 AM
haseeb
Jan 15, 2009 03:06 PM
estiller
Sep 15, 2007 07:16 PM
tkelly13
17
Jun 5, 2006 11:54 AM
