Link G4+ PnP Ecu help
Old May 22, 2022 | 10:25 PM
MIG23T's Avatar
Hi all,
Looking to see whether anyone on here is a bit of a link ecu whiz. I have a PnP ecu in my car and am having a slight issue with the thermo fan. Key the car to accessories and the thermo fan roars to life and stays on. Ive got full access to the link g4+ software when connected to the laptop. Question is, how do I switch the thermo fan to operate as normal ~coming on at the set temperatures and shutting off when it needs to, instead of running the entire time.
In the aux settings for fan 1 with the polarity set to low and the fan is ON, changing the polarity to high and the fan will cut off. I didnt think that was normal operation for the fan?
Would other symptoms like a failing coolant sensor on the thermostat housing be giving me this issue or is there a setting in the ecu I need to change around? I don't believe the fan control module is the culprit, it isn't that old but I will be borrowing a friends later this evening to test anyway.
Cheers.
Old May 23, 2022 | 08:54 PM
Tim M's Avatar
5 Year Member
Wish I could help, but interested in the outcome as I've ordered a Link ECU for our Evo 5.
Curious, did this just start happening or always from the installation?
Old May 24, 2022 | 06:19 PM
MIG23T's Avatar
It was fine with the oe fan and oe ecu. Ive changed it to a slim spal fan, depinned and repinned the connectors to suit. I cant see that being the root cause. Its an odd one being a PnP ecu, it should just pick up as per normal.
I did find the fan control module had popped the 50a fuse which Ive replaced. Once i sort it out ill let you know.
Old May 24, 2022 | 06:50 PM
Jonno99's Avatar
There's a Link forum, you might want to add yourself on that and ask the questions.
Old May 26, 2022 | 02:41 AM
MIG23T's Avatar
hey Tim, I ended up consulting the tuner who remotely fixed it and uploaded the new map.
If you get stuck, I can bring up the settings on mine you can follow.
Cheers.
TJung
Jan 30, 2013 12:32 PM
siony
May 8, 2010 07:16 PM
lancebin
Mar 7, 2010 09:20 AM
Deepnine
Jul 8, 2009 06:05 AM
sparky
Jul 9, 2006 04:45 PM
