How many 8-9 original owners are left
Old Jan 12, 2023 | 06:31 PM
  #106
spdrcr456's Avatar
I just replaced it with used units i found for sale. I need another one now. So need to find one.
Old Jan 12, 2023 | 06:40 PM
  #107
91355evo9's Avatar
Ah ok. I need one now, mine just went bad. I have a hard time figuring out if the used ones are actually functioning
Old Jan 12, 2023 | 06:49 PM
  #108
spdrcr456's Avatar
You can test them. Give it 12v power for a second and it will click. Also can test it once it's installed with a sequence of gas pedel pumps and key cycles. Can look that up.
Old Jan 12, 2023 | 07:42 PM
  #109
kaj's Avatar
kaj
Originally Posted by 91355evo9
Did the motor let go?
I see 200k stock motors and rebuilt with much lower miles. Just curious what leads to need for motor built
I just turned 60k miles and wouod like to keep mine going for a long time
Most blown engines I see are due to a bad tune. If it's of poor quality or pushes the engine beyond it's limits.... **POOF**. My car's original engine lasted about 127k before developing low compression in cylinder 3. I can't vouch for what the car had been through before I bought it... but I can imagine. I'm expecting my current engine to go at least 100k miles. Much longer than the car should live LOL
Old Jan 12, 2023 | 07:44 PM
  #110
91355evo9's Avatar
Thanks, excellent info!
  #111
91355evo9's Avatar
Ah ok, that makes sense. Stock motors seem to be ok till 200k all stock car from a few peoole who posted here
Old Jan 12, 2023 | 08:00 PM
  #112
kaj's Avatar
kaj
Yes. It's on a scale. You have stock HP/reliability at one end and high HP/broken on the other. Adjust the slider to your comfort level haha.
Old Jan 12, 2023 | 08:07 PM
  #113
91355evo9's Avatar
I am on old man scale 😈👻😎
Old Jan 12, 2023 | 08:14 PM
  #114
kaj's Avatar
kaj
Same. I've done the high HP thing before. It was fun, but got old quick. My current car is the most fun I've ever had while driving. It does everything perfectly. I ended up putting in a brand new engine from Mitsubishi. Best decision ever.
Old Jan 12, 2023 | 08:15 PM
  #115
spdrcr456's Avatar
My scale is broken. I'm on 27ish lbs of boost on a stock 220k motor. For the last 150k miles. Only cams and headstuds.
Old Jan 12, 2023 | 08:18 PM
  #116
kaj's Avatar
kaj
Boost is fine if you have enough cooling. I've been running 28psi with an HTA71 on e85, on the old engine and new. Will last forever. With 220k miles, maybe it's a bit tired, but should be fine
Old Jan 12, 2023 | 08:27 PM
  #117
spdrcr456's Avatar
Right. The tune is solid. Drives so perfect. Has since it was tuned in 2008. Retuned a few years later to add tephra mods. If it's tired I don't feel it. Pulls just as hard. Only issue I ever had was blowing spark out at high rpm. COP kit fixed that.
Old Jan 12, 2023 | 08:34 PM
  #118
kaj's Avatar
kaj
Blowing out spark? Dang. How much WHP are you making in that thing??
Old Jan 12, 2023 | 08:42 PM
  #119
spdrcr456's Avatar
Not really sure. Never dynod it after the fuel system. Turbo and tune and etc. Just street tuned. Hp isn't that important to me. Drivability. Power delivery. Handling. and how it feels matters. I run an e85 tune at 28lbs. And a pump tune at 23lbs. I know I have ran side by side with an 850hp ctsv. I'm sure I'm way lighter though.
Old Jan 12, 2023 | 08:45 PM
  #120
spdrcr456's Avatar
Only time it was dynoed was way back in 2007 on the AMS dyno at their old shop. And it was only 320hp. All stock except for intake exhaust and mechanical boost controller. With basic ams tune.
