Evo 7 gta Weird idle on cold start
Old Jul 2, 2022 | 09:00 PM
OGHalo's Avatar
Vehicle is currently running rich and when I do a cold start the vehicle would feel its about to die a couple of times but its fine once warm up, I have no idea if it's the maf, map, 02 sensor, tps, iacv, or a vacuum leak, I clean everything except for the tps, no check engine lights, I did unplugged the maf while the vehicle is running and still keeps running without it, any ideas?
Here's a couple of links of the cold start
Old Jul 3, 2022 | 06:31 AM
Biggiesacks's Avatar
You should do a boost leak test.
Old Jul 3, 2022 | 03:49 PM
OGHalo's Avatar
Turns out that this hoses was disconnected, not sure if this will fix the running rich problem
Old Jul 3, 2022 | 06:48 PM
OGHalo's Avatar
Car still has the weird rough start up after checking the vacuum hose
Old Sep 19, 2022 | 01:40 PM
OGHalo's Avatar
The weird start up was from the battery where it was only doing 9 cranking amps instead of 400, thats why I had a dead battery each time I attempted the start up, already replace the battery and starts up no problems
jimbos_viii
Jan 31, 2022 06:00 PM
Yazer
Oct 16, 2018 07:27 AM
mrm95
Dec 7, 2013 11:02 PM
SilverLanEvo
Jul 5, 2011 10:52 AM
mmartahus
Jul 8, 2009 03:02 PM
