Trans or Transfer Case Issue?
Old Dec 25, 2022 | 06:56 PM
steven121's Avatar
Recently I noticed when I turn left or right my the car would make a constant thump noise.
When I was driving home I did the same thing to see if it was the suspension. The car did it again. This time it was different
Now when I put the car in 1st-5th and let the clutch out slowly the car would make the same thunk noise but it would keep doing it over and over. Now when I put the car in reverse the car would drive fine
T-Case does whine and is due for a rebuild. But my question is this a symptom of the transfer case, or is this a transmission problem?
Old Dec 27, 2022 | 06:28 PM
CurseDSM's Avatar
It sounds like a bushing problem. Clunking is usually worn out subframe stuff. I would take a look at your rear end bushings and or your mustache bar bushings. Maybe a carrier bearing as well, tough to tell without the car being here.
Old Dec 28, 2022 | 12:57 PM
mitsuatb's Avatar
You might want to jack up one wheel at a time and see if you feel play in CV joints and wheel bearings. Then check the drive shaft. Pulling trans / t case is a job. Make sure you are not having an easier to fix problem. CV joints are more active and moving through an angle at the front when turning.
Mitsuatb
Old Dec 28, 2022 | 04:59 PM
osetsky's Avatar
I gotta keep tightening sway bar end links to stop a clunk, so maybe those as well. Also, adjustable links from whiteline chew dix. Or I suck at them. But no way on earth I suck. GF said so. Mom...well she had issues.
Blueevo1999
Dec 21, 2021 04:43 PM
mattyboost
Nov 6, 2012 07:49 PM
toyotabike
Jul 6, 2010 08:31 PM
midwestmonster
13
Sep 22, 2007 04:36 AM
fruhead
May 3, 2007 09:36 PM
