Help Needed! Rattling Sound when Accelerating - Mitsubishi Evo 6
Old May 23, 2023 | 01:13 PM
Blackforestevo's Avatar
Hello fellow Evo enthusiasts,
I'm seeking some assistance regarding a perplexing issue I'm experiencing with my Mitsubishi Evo 6. Whenever I accelerate, I hear a distinct rattling sound coming from the middle/rear section underneath the car. It has a metallic quality to it, and it only occurs when I apply throttle and put the engine under load. When the car is coasting, there are no unusual noises.
I've done some initial investigation, but I'd greatly appreciate your insights and expertise on this matter. Here are some details:
  • The sound appears to originate from the middle or rear of the vehicle.
  • I have checked the exhaust system for loose components, damaged hangers, or holes in the exhaust pipe, but everything seems to be intact.
  • The heat shields appear to be properly secured and show no signs of contact with other parts.
Considering the nature of the sound and its occurrence only during acceleration, I suspect the issue might be related to the rear differential or the driveshaft. Could it be possible that there is excessive movement in the rear differential when torque is applied, causing the noise?
I would greatly appreciate any insights, suggestions, or experiences you could share regarding similar issues or potential causes. If you have encountered this problem before or have any expertise with Mitsubishi Evos, your input would be invaluable in helping me diagnose and resolve this issue.
Thank you in advance for your time and assistance. I look forward to hearing your thoughts and recommendations.
Best regards,
Blackforestevo
USMC Brad
Nov 6, 2021 04:29 PM
Jstyle007
May 16, 2010 05:46 PM
sdfontanini
Apr 19, 2008 01:25 PM
Blue Evo 8
26
Jan 23, 2007 08:08 PM
WickedWhiteRS
Jun 29, 2006 09:10 AM
