Can you remove a rear subframe with jack stands and a car jack?
Old Oct 21, 2023 | 02:30 PM
Icecruncher's Avatar
Can you remove a rear subframe with jack stands and a car jack? I need to rust proof my car.
Nevermind I just realized the car won't be high enough to do **** all when it's dropped lol.
Old Oct 22, 2023 | 08:39 PM
ViciousLSD's Avatar
i've done part of it. as i mentioned in another thread, there a guy (& gf) on youtube that removed the tank and subframe using floorjacks and jackstands
Old Oct 23, 2023 | 05:14 AM
I couldn't find anything like that when I searched. Any idea of what the title may be? If I could get a head start that would be great. Thanks for replying.
Old Oct 23, 2023 | 07:29 AM
ViciousLSD's Avatar
@Icecruncher this guy
Old Oct 23, 2023 | 10:21 AM
ViciousLSD's Avatar
Old Oct 23, 2023 | 10:58 AM
Kevin.'s Avatar
Rear diff gets in the way of dropping fuel tank:
Old Oct 23, 2023 | 12:04 PM
ViciousLSD's Avatar
https://www.youtube.com/watch?v=rVKQGMB34AE&t=1309s
just like doing the front diff/transmission, its harder if you dont lower the subframe. I use 4 small jacks. its probably the same plus an assistant jack operator for the tank
Old Oct 23, 2023 | 02:06 PM
kikiturbo's Avatar
I built the whole car up from almost bare shell using jackstands and a relatively large hydraulic jack. Bear in mind, there are no lifts in rally service areas... hell, even in pro rally workshops they do it all on the floor for training..
anyway... just support the diff with the jack, take all the bolts and nuts off the subframe and it just drops off... Tank is a 4 nut job and some fiddling with hoses/wiring.. Removing fuel and tank pipe makes life easier... You will probably break the bolts that hold that little shield that protects the filler pipe..
Old Oct 30, 2023 | 03:18 PM
SsZERO's Avatar
Yeah, if you can get the floor clearance needed with jackstands, the jack points are on the chassis of the Evo, so it can rest on jackstands. That way anything you want to remove can be dropped as long as there's enough room between the bottom of the car and the floor.
ErnGotti
Evo X How Tos / Installations
Apr 3, 2012 08:35 PM
702RSevo
Nov 21, 2006 02:49 PM
bolsen
Nov 12, 2006 06:28 PM
bolsen
May 4, 2005 07:26 PM
