What's the best dual pumper setup?
Old Mar 1, 2024 | 09:08 AM
chizwizzzzz_'s Avatar
I currently have the buschur dual pumper kit on my evo 9 and it has the notorious leak issue lol. I was wondering what are you guys using for your dual pump setups! Please no leaky ones lol
Old Mar 1, 2024 | 09:30 AM
Evo9isLife's Avatar
5 Year Member
I dont personally use them (im stock), but Radium makes top tier fuel system products, including dual pumpers.
Old Mar 1, 2024 | 10:18 AM
schuhie's Avatar
I would get a better idea of why/where yours is leaking and probably just fix it.
Old Mar 3, 2024 | 08:09 AM
CurseDSM's Avatar
Bulletproof racing has the best one by far. Look at those your wont be disappointed.
Old Mar 4, 2024 | 09:51 AM
Appreciate your guy's responses! Will definitely look into those setups! TY
Old Mar 4, 2024 | 09:52 AM
Yeah. Well I already asked a shop to fix it. They already JB welded it and everything and it still leaks
Old Mar 5, 2024 | 07:50 AM
blackline's Avatar
5 Year Member
Radium/BPR/EvoSpec
Old Mar 5, 2024 | 02:50 PM
Pal215's Avatar
What are your current power goals?
You may not need a double pumper setup in the first place, which would simplify your setup, make it cheaper, and make it more reliable. You'll be able to avoid additional leak issues as well as the risk of one pump failing during high boost. Walbro makes a 525lph and a 535lph pump (without the internal check valve) which are good to over 700+hp. A single 450lph pump is good to the upper 650hp range.
Old Mar 6, 2024 | 07:31 AM
Well I'm trying to hit 800++ hp on my ER 2.2 and with an fp zero. I don't really wanna max out a fuel pump esp I'm running e85. Currently I'm on dual 525s that the old owner put to just make sure it doesnt run out of fuel. Thanks for the input!
NewEvolutionIX
Jul 8, 2015 01:14 PM
pcasso87
Sep 9, 2010 10:58 AM
reyrey
Mar 19, 2009 03:38 PM
