Evo 8 stalls plus burning rich
Old Mar 1, 2024 | 12:19 PM
New Era's Avatar
Hello, I have a 2003 evo 8 that I am working on the evo will start up and then it will want to stall unless i keep giving it some revs the car worked fine before until the customer/previous owner decided to mess with the boost controller he said he felt more power at first then after a few weeks he said he noticed the car went very limp and he noticed the symptoms of the car wanting to stall we changed the spark plugs we changed the fuel pump got a new air intake because last one was pretty busted up at one point the car wouldnt even start anymore but started again after the new plugs you could definitely tell it was burning rich by the smell and amount of smoke I am not too experienced in figuring out problems like this any information would help thank you
Edit: the car now starts and runs however is in limp move when driving i can only go up to 20mph what i did was i fliped the fuel relay number two but now the fuel levels dont show even when i flip it the right way gonna replce it and hope for the best
Old Mar 3, 2024 | 07:51 AM
WRC-LVR's Avatar
Wel in order to help we need better info...What mods are on the car who tuned it and what was the previous known boost and AFR ?
1. boost leak test first. hoses could be leaking or blown off. Fix or replace any issues
2. then check the waste gate adjustment. Should be about 1/2 the peg showing . You would need to pull adjustment over to the peg to hold tension. Too much tension will allow runaway boost.
3. Then check the tune and AFR using wideband. Make sure the boost level is safe and doesnt exceed what it is tuned for
4. check the turbo at start up, if you hear screeching the cold side wheel is hitting the compressor housing = new turbo.
Old Mar 3, 2024 | 10:09 AM
New Era's Avatar
I wish I could tell you what all was done to this car we got no clue because this is a auction car so we dont know all too much on whats been done the tune or anything I did a compression test (dry) just to check and everything read around 130 I am stuck on this car and trying to figure out what is going on with it I didnt hear any noise from the turbo I will do a boost leak test
Old Mar 3, 2024 | 01:02 PM
osetsky's Avatar
Pictures then, and lots of 'em so the good eyes can see what's up on the surface.
Old Mar 3, 2024 | 03:05 PM
New Era's Avatar
Ill make sure I take a bunch of them tomorrow thank you for the help guys seriously helping me with this headache
Old Mar 12, 2024 | 02:13 AM
IsisHodge's Avatar
Any update?
New Era
Mar 1, 2024 03:55 PM
cocoon
Sep 20, 2015 08:25 PM
DSMvsWhatever
Jan 10, 2010 09:25 PM
mh37001
10
Oct 29, 2008 12:39 PM
Silver05Bullet
Oct 19, 2005 03:12 PM
